Hello Guest it is October 24, 2026, 01:40:29 PM
Author Topic: GSim Mach4 Material Removal Simulator  (Read 193873 times)
Re: GSim Mach4 Material Removal Simulator
« Reply #50 on: January 31, 2015, 01:56:59 PM »
OK here TIS.  I like the Imbedded values I wish Mach4 did that.
« Reply #51 on: January 31, 2015, 03:22:08 PM »
Art, could I design a totally unorthodox tool like a disk (imagine a sawblade) with a semicircular rim radius? and have the centre of the disk to be the point anchored to the toolpath lines? So imagine a disk cutting with its faces back and forth.  This is for foam cutter machine. Maybe I could design the  disk as a solid and import it into the program? And how about we also define the stock accurately, lets say if you could also open a solid (stl, step, obj or some other solid file).
thanks,
F
« Reply #52 on: January 31, 2015, 04:54:53 PM »
OK here is an update/ answer(;-)
I redownloaded the lastest ver and set it up in another drive as a DEMO version and Gsim WORKS (;-)
BUT it still will not work in the original profile Mach4 Industrial version.
(;-)TP
« Reply #53 on: January 31, 2015, 05:26:55 PM »
You're the only one using the industrial version. It's not available to us mere mortals.
« Reply #54 on: January 31, 2015, 06:03:34 PM »
HIYA Gerry,   Unless you are doing conditional parametric Gcode and G65 Macros  I don't see where  you are missing anything (;-)
There IS a pro version Gcode Editor but I have not seen that yet(;-)
ART, Here is are TEST Gcode files IF you want something to PUSH or punish Gsim (;-) Mach4 can run it BUT not Gsim.
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
« Reply #55 on: January 31, 2015, 09:12:23 PM »
Hi Terry:
  I think I found the problem that stopped those two files from running, Im simming them fine now. (Though the first pass is at z=0 so does nothing, the rest simulates kinda nice looking...
 New version in a few minutes that shoudl fix that. IT coudl also explain some crashing issues... IT DOESNT explain how roadrunner coudl have failed.. but
you never know... :)
Art
Offline ART
  •  1,703 1,703
« Reply #56 on: January 31, 2015, 09:17:07 PM »
Hi All:
  Version 1.005 allows for full arcs.. ( the previous files issue.. just a typo.. )
It also fixes a possibel crash issue in arc interpolations..
Thx
Art
« Reply #57 on: February 01, 2015, 01:58:01 AM »
no luck here with the test files.
Offline dude1
  •  1,253 1,253
« Reply #58 on: February 01, 2015, 02:18:28 AM »
try updating your direct x its one of the thing i had to do
also vista is a hog of a program it  takes one gig to run it
Offline ART
  •  1,703 1,703
« Reply #59 on: February 01, 2015, 06:06:58 AM »
I knew it woulnt fix your problem Terry, you couldnt load Roadrunner... which is really weird.
Im not sure their would be a different. Have you tried running vanilla wxMach with no screenset?
  Any Difference?
 Art
