Hello Guest it is October 24, 2026, 12:45:48 PM
Author Topic: GSim Mach4 Material Removal Simulator  (Read 193795 times)
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: GSim Mach4 Material Removal Simulator
« Reply #90 on: February 04, 2015, 11:21:16 AM »
Hi Karl:
  Im looking into it. :)
Thx
Art
Offline ART
  •  1,703 1,703
« Reply #91 on: February 04, 2015, 11:27:46 AM »
Karl:
 Which file are you simming? I seem to be working ok here... but I did notice what you mean about the displays, Ill fix those up.
Thx
Art
Offline ART
  •  1,703 1,703
« Reply #92 on: February 04, 2015, 11:36:32 AM »
Hi Karl:
  I did find a bug in the VBit code.. new release soon to fix it. Still dont know why you crashed, but it may be related..
Art
« Reply #93 on: February 04, 2015, 11:55:27 AM »
HIYA Art, I just noticed that in the 4 veiws you have the top and front bottons crossed.
Still working fine here except it does NOT  drill the holes (;-) must be a dull drill bit. It just mushes down through the material and springs back up.
JUST TEASING, it does show the tool motion  just no visual hole at that location in the material.
Offline ART
  •  1,703 1,703
« Reply #94 on: February 04, 2015, 12:05:26 PM »
Heres a new version guys, turns out any VBit would have failed to cut.. this version shoudl also be faster. Ill check the
other bits.. I may have screwed up one of those..
Art
Offline dude1
  •  1,253 1,253
« Reply #95 on: February 04, 2015, 12:09:33 PM »
br549 send art a copy of M4 industrial so he can get it going a see whats different
« Reply #96 on: February 04, 2015, 12:24:55 PM »
Here's the file I play with the most and the one that caused the crash in Extreme resolution.
Terry.  On my machine not only do the peck drill cycles show the motion, it also leaves holes in the model on the screen
Karl
(Karl Kirk Cir/Sq)
(Mill 4)
(Karl's Emco Mill)
(MECH_247)
(12/05/08)
#1=40        (# of Passes/Quadrant)
#2=[90/#1]   (Angular Increment)
#3=[2./#1]   (Linear Increment)
#4=[0-#2]    (Starting angle)
#5=[0-#3]    (Starting Y Position)
G20 G17 G40 G80 G50
G90
(G55)
G00 Z.3
G00 X.5 Y0
M3
G90
G0 T00 Z.2
G1 F50.0
M98 L[#1/2] P0004
#4=[45-#2]
#5=[1.+#3]
M98 L[#1+1] P0005
#4=[135-#2]
#5=1.0
M98 L[#1/2] P0006
G00 Z.3
X.5
G51 Y-1.0
M98 L[#1/2] P0004
#4=[45-#2]
#5=[1.+#3]
M98 L[#1+1] P0005
#4=[135-#2]
#5=1.0
M98 L[#1/2] P0006
G50
G00 Z0
G00 X0 Y0
M5
M30
O4
#4=[#4+#2]
#5=[#5+#3]
G1 X [.5*cos[#4]] Y[.5*sin[#4]] Z-.05
G1 X1. Y#5 Z-.5
M99
O5
#4=[#4+#2]
#5=[#5-#3]
G1 X#5 Y1. Z-.5
M99
O6
#4=[#4+#2]
#5=[#5-#3]
G1 X-1. Y#5 Z-.5
M99
« Reply #97 on: February 04, 2015, 12:37:38 PM »
Ver 13 also crashed in same manner.
Karl
Offline ART
  •  1,703 1,703
« Reply #98 on: February 04, 2015, 01:55:52 PM »
Karl:
  Weird, runs fine here.. rigth to end onm extreme. Ill keep looking. I see the top and rigth side doesnt machine away.. and it should. :)
Art
« Reply #99 on: February 04, 2015, 02:31:25 PM »
I can make it crash repeatably
   Load Mach4
    Enable
    Recent File
    Cir-Sq_Var.tap
    Diagnostics
   Gsim
    Resolution
    Extreme
    Sim speed 100%
    Reset
  and it will crash when the prep for sim gets to about 5%
