Hello Guest it is October 24, 2026, 01:40:38 PM
Author Topic: GSim Mach4 Material Removal Simulator  (Read 193875 times)
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: GSim Mach4 Material Removal Simulator
« Reply #120 on: February 06, 2015, 07:25:54 AM »
Well, I guess should it get popular enough and I end up putting it in an app window rather than a dialog, I will
also add the variables necessary to allow a stock designation. I always resist adding complexity, its just more
things to get buggy or confuse the users that just want a quick something..
   I guess I can make it with a "Pro" checkbox if I go there. :)
Thx for the comments and the testing guys, I do appreciate it. Looking at download numbers though it
could be quite awhile before it justifies further work. Does seem to work pretty well on the final version
though, so Ill let it steep..
Thx
Art
« Reply #121 on: February 06, 2015, 08:33:59 AM »
Art
   What you have given us at this point is absolutely WONDERFUL.  It is the sizzle in Mastercam and other high end cam software programs.   At the end of my class, I demo mastercam in order to entice them to take a mastercam class next, and what you have added to Mach 4 is what impresses the students to take the mastercam.  Of course it always helps that I always "oh and ah" while I demo it.  If you add nothing else, what you have given me is awesome tool, and I am grateful.  If you decide to do further developement, I will be interested, of course.
  Once again, Thanks Art.
Karl
Offline dude1
  •  1,253 1,253
« Reply #122 on: February 06, 2015, 01:18:06 PM »
2nd that
« Reply #123 on: February 06, 2015, 04:24:35 PM »
Art,
I would also like to throw in a vote of support
It's working well with M4 2214 and Darwin 2176 on Win7 32 bit. Machine is 3GHz Core Duo 4Gb with 1Gb Video supporting Open GL 3.3
Graham
Graham
« Reply #124 on: February 13, 2015, 05:51:04 PM »
Art
  I just got my new faster computer to try GSim on and I can't get Mach 4 to load Gsim.  When Mach 4 runs I get the "Failed to load shared library Gsim" error message (see photo).  I seem to remember seeing that problem earlier but can not find it. Do you remember the fix for this problem?
Karl
« Reply #125 on: February 13, 2015, 06:48:11 PM »
I did a search in "side by side" and found the January 30 post by me and the instructions about running the "vcredist_x86.exe" file the gearotic directory after installing Gearotic program.  That solved the "failed to load" problem.  Now everything runs until Mach 4 trys to load Gsim.  Here I get a Mach 4 'gui' error message.  What do I do next?
Offline ART
  •  1,703 1,703
« Reply #126 on: February 13, 2015, 07:45:08 PM »
Karl:
  Are you sure its the latest version.. the prior to last version did that one in Win7 as I recall...
Art
« Reply #127 on: February 13, 2015, 08:11:14 PM »
I am using 1.016
« Reply #128 on: February 13, 2015, 08:18:13 PM »
it does not even get to the rotating image.  It gives the error message as soon as GSim is selected and when I say "close program" (only option) I have the desktop.  When I have the roadrunner loaded, and I select GSim the MDI window displays "GSim context: X:1024 Y:845"
Karl
« Reply #129 on: February 13, 2015, 08:20:20 PM »
It is a win 7 32 bit machine.
