Hello Guest it is October 24, 2026, 12:45:49 PM
Author Topic: GSim Mach4 Material Removal Simulator  (Read 193796 times)
Re: GSim Mach4 Material Removal Simulator
« Reply #70 on: February 01, 2015, 08:55:54 PM »
V.007 loaded and it failled to loadGsim on the test file. It ran and ran and ran but no load. I gave it a full minute to load.
« Reply #71 on: February 01, 2015, 09:02:28 PM »
V.008 same as V.007 Gsim fails to load, same history message.
« Reply #72 on: February 01, 2015, 09:51:06 PM »
Art
  I tried loading ver 1007 on my win 7 machine.  Seemed to load ok but got the message in the attached photo.  When I "unpaused" it, the tool moved correctly but left a black screen behind all movements.  Then on 3rd try, it all hung including Mach4 and I had to  stop it using task manager.
Karl
« Reply #73 on: February 01, 2015, 09:57:40 PM »
Same results with ver 1008 as 1007.  I did not copy the directory, just the 2 .dll's and "GSim.m4wp" & "GSim.sig" files.  Is this OK?
Karl
« Reply #74 on: February 01, 2015, 10:10:53 PM »
Recopied the 1005 files and it works as before.
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
« Reply #75 on: February 02, 2015, 07:24:05 AM »
Hi Karl:
  Sorry I broke it on you, Im playing with variosu OpenGL structures hoping to find a common thread for the problem..
Here is 1.009 which should add more messages and fix your trouble. (hopefully)
Thx
Art
Offline ART
  •  1,703 1,703
« Reply #76 on: February 02, 2015, 09:22:53 AM »
Hi Guys:
  Thank you to all that have been testing. This version should fix the issue of Sim firing , but not opening. It now works on my test system that
had been havig trouble as well , please let me know your experience..
Thx
Art
« Reply #77 on: February 02, 2015, 10:14:43 AM »
OK IT ran the test file. BUT it took 8min 30secs to load the image and the SIM ran extremely SLOW. At that speed it would have taken about 30 minutes to run the sim.
Offline ART
  •  1,703 1,703
« Reply #78 on: February 02, 2015, 10:46:44 AM »
Terry:
    Can you send me the file... I know theres still issues with some files, and I suspect its simply a resolution issue..
Art
« Reply #79 on: February 02, 2015, 11:05:01 AM »
HIYA ART, Look at reply #54  File Name "Hemi_cut.tap"
