Hello Guest it is October 24, 2026, 12:46:05 PM
Author Topic: GSim Mach4 Material Removal Simulator  (Read 193803 times)
Re: GSim Mach4 Material Removal Simulator
« Reply #130 on: February 13, 2015, 08:28:11 PM »
History (MDI) window displays "Vertex Buffers requested but not available" after a roadrunner or arc test file is loaded in Mach 4  could this be involved?
Offline dude1
  •  1,253 1,253
« Reply #131 on: February 13, 2015, 08:29:18 PM »
try updating your graphxs it would not run on my computer to I installed the lasted drivers I have a gaming laptop so its a bit different
Offline dude1
  •  1,253 1,253
« Reply #132 on: February 13, 2015, 08:29:44 PM »
yes
that's problem has come up before one thing you can try is loading up gearotic
« Last Edit: February 13, 2015, 08:32:29 PM by daniellyall »
« Reply #133 on: February 13, 2015, 08:34:03 PM »
Here's the entire history file
« Reply #134 on: February 13, 2015, 08:41:06 PM »
Thanks Daniel.   I loaded Gearotic and after running the vcredist_x86 file gearotic runs fine.
« Reply #135 on: February 13, 2015, 08:44:57 PM »
That sounds like a possible cause, Daniel.  do you know where I can find the latest drivers.  I wonder if this machine even has openGL installed on it?
Karl
Offline dude1
  •  1,253 1,253
« Reply #136 on: February 13, 2015, 09:00:38 PM »
you would have to look through this thread but I think that was for XP I just loaded up a new game it had the drivers in it.
you can go into hardware config in your control panel and up date your graphix drivers
« Reply #137 on: February 13, 2015, 09:12:21 PM »
The more I think about it, it can not be the open Gl drivers because Mach 4's graphic window is an openGl driven window and it works fine.  It just that GSim won't start.
Offline dude1
  •  1,253 1,253
« Reply #138 on: February 13, 2015, 09:14:24 PM »
could be different GL version latest will confirm. art will be online soon so he will jump in
« Reply #139 on: February 13, 2015, 09:50:23 PM »
I have openGl 1.4 with 56 extensions.  do I need 2.0 or may 4.0 to run GSim?
Karl
