Hello Guest it is October 24, 2026, 12:45:43 PM
Author Topic: GSim Mach4 Material Removal Simulator  (Read 193794 times)
Re: GSim Mach4 Material Removal Simulator
« Reply #30 on: January 30, 2015, 11:49:56 AM »
RoadRunner it is.
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
« Reply #31 on: January 30, 2015, 01:53:26 PM »
Interesting... I wonder why no entities.. weird really..
Ill investigate.. :)
ARt
« Reply #32 on: January 30, 2015, 02:21:45 PM »
Art
  When trying to install GSim on my Windows 8.1 tablet, I get "Fail to Load shared library 'GSim.m4pw' (error 0:the operation completed successfully)" when I try and open Mach 4.  Any idea what I am doing wrong.  I tried to install on the D: drive because it has a lot more room on it.  And got the message.  So I uninstalled it, and reinstalled in on c:  I still get the same message.
Karl
Offline ART
  •  1,703 1,703
« Reply #33 on: January 30, 2015, 03:42:45 PM »
Karl:
  I "think" its the C++ support files. Try installing the Demo of Gearotic.. Ive heard that fixed a couple
 of Darwin installs that had the same issue....  the vcredist_86.exe seems to have more than 1 version, and the one
in the gearotic install worked at least once...
Let me know what happens..
Art
« Reply #34 on: January 30, 2015, 06:56:22 PM »
I installed the development version of Gearotic and left the check mark for installing the redistribute, checked.  When I tried to run Gearotic I got the "side by side config" error message.  I uninstalled Gearrotic and Mach4 & deleted the directories.  Rebooted my tablet. Reinstalled Gearotic, this time unchecked the install redistributable option. Ran ran gearotic, again I got the "side by side config" error message.
Karl
« Reply #35 on: January 30, 2015, 07:22:54 PM »
I just went to the Gearotic Motion directory and ran the "vcredist_x86.exe" and now Gearotic program runs.
Karl
« Reply #36 on: January 30, 2015, 07:29:43 PM »
Installed Mach4 and GSim and both work.  Thanks Art.  It is such a COOL program.
Karl
Offline ART
  •  1,703 1,703
« Reply #37 on: January 30, 2015, 07:39:32 PM »
Karl:
  Very interesting.. it seems some systems reject the runtime files unless you run them manually.. ( A security issue I assume..)
Thanks for the information though, it will probably help others.
 I have foudn a few errors Im fixing, an update shoudl be tomorrow at some point which will hopefully run
on many system sit woudlnt run on before..
Thx again
Art
Offline ART
  •  1,703 1,703
« Reply #38 on: January 31, 2015, 07:56:06 AM »
Hi Guys:
 Ive found a few errors and have hopes this ill fix many of your problems found...
This version is 1.004 and does things a bit better in Wiondow organisation..
Thx
Art
« Reply #39 on: January 31, 2015, 09:53:38 AM »
Art
  I downloaded the latest version.  Extracted the files on both of my machines, copy and pasted the files into the "Mach4Hobby/plugins" directory and ran mach4.  I could see no differences in the operation of GSim. It worked correctly as before.
   Attached is a file I have my students write and it is sure fun to watch run on you simulator.  Note: although the G20 is programmed, it uses the metric tools.
Karl
