Hello Guest it is June 10, 2026, 05:13:24 AM
Author Topic: Screendesigner "machscreen"  (Read 339083 times)
0 Members and 6 Guests are viewing this topic.
Re: Screendesigner "machscreen"
« Reply #10 on: April 09, 2009, 08:41:18 AM »
Klaus,
   I edited your first post in this topic to include a link to your screen designer. I have downloaded V1.14b but haven't had time to play with it yet. Thank you very much for working on this.
« Reply #11 on: April 09, 2009, 09:29:42 AM »
Hi Gerry
when you talk about locking, do you mean lock for mouse move in MachScreen? Because in your last post you wrote "When scripts are edited in Mach3 all the controls become unlocked". When you lock a control in MachScreen and start the G-Code or script editor, after finishing the editor the control is still locked. What do you need the feature "lock all objects" for?
happy Easter
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #12 on: April 09, 2009, 10:10:25 AM »
Yes, lock for mouse. When I edit a button script in mach3, all my controls are no longer locked for mouse.
« Reply #13 on: April 09, 2009, 10:23:57 AM »
Hi Gerry,
do you really mean Mach3 and not my screendesigner "MachScreen"?
Klaus
« Reply #14 on: April 09, 2009, 10:29:43 AM »
Yes, after I create a screen, I load it into mach3 and edit the button scripts. When mach3 saves the screen with the button scripts, it appears to unlock the controls for mouse movement. So when the screen is loaded back into a designer (either yours or screen4), the controls are no longer locked for mouse.
« Reply #15 on: April 09, 2009, 10:56:49 AM »
Hi Gerry,
unfortunately the lockbit information isn't saved to the set-file and therefor not interpreted by mach3. I don't want to put an information into the setfile which would be unknown to Mach3. You can, on the other hand edit your script in the screendesigner. Select the control you want to assign the script, doubleclick "execute code", dialog appears, asking you G-Code / VB Script assign later, after reply to that, you are in the MachScreen editor.
Klaus
« Reply #16 on: April 09, 2009, 12:42:47 PM »
That makes sense, thank you for clearing that up. I've been working in Screen4, where I couldn't edit the scripts. Now that I can edit them in your designer, i should no longer have the problem. Thanks again. :)
Offline Greolt
  •  956 956
« Reply #17 on: April 09, 2009, 05:04:32 PM »
Hi Greg,
I found the bug and corrected it. The new version is V1.14b
Thanks.   :D
« Reply #18 on: April 14, 2009, 05:57:21 AM »
Hi Scott,
I think I found the bug of disappearing digits on the dro and fixed it, this wasn't a VISTA 64bit problem. I also implemented a frame to show a settable window size. The new version is V1.14c and is downloadable from www.kd-dietz.de
Klaus
« Reply #19 on: April 14, 2009, 09:44:47 AM »
Ok Klaus,
    I will "Fool" with it, again and see if I can make something else fail (bug test).  BTW: Thank you for your time in doing this!!  Your work is GREATLY appreciated.
   I will state here publically, so everyone will be aware, If you want to Send me your "Source Code" for the screen designer, and what I will do, it go through, and do an "English" laungage "INstaller" for you if you want.
I realize once you get into the screen set you can change the runtime laungauge pack, but the installer is all in your laungauge.
I have a copy of VS2003 (that I do plugs in), and a copy of VS2008 that I do the (Plugin Wizard stuff in "Eds Stuff").  I can take your source code, and update all the stuff to English, and then zip it up and send you back the code for you to compile.
Thank you for your work in the BADLY needed area!!!!!!! You are a true asset to the Mach3 community.
Scott
