Hello Guest it is November 11, 2026, 09:23:10 PM
Author Topic: Screendesigner "machscreen"  (Read 382071 times)
Re: Screendesigner "machscreen"
« Reply #160 on: September 09, 2009, 08:22:35 AM »
Just wanted to add a few things that Klaus forgot to mention that he added or fixed.
you can un tick the "Pos Selection", and then when you copy a Single or group of items and go to another page, or even the same
page, you can just hit "Cntr-V" and it will paste it, in the exact same location as the original (OR, you can go into options and set, a
X and Y pasting offset if you wish!!! per paste you do!!!), no dialogs pop up this way asking what you want to do on each paste.
Also, he added a "Select only objects that are fully in the select box", this is a Great addition, i.e. if you have many objects on top
of a bit map, you can now from outside the bit map, run your select box in and surround the objects you want, Without the bit map also
being selected.
scott
« Reply #161 on: August 13, 2010, 06:25:51 AM »
Hi Scott,
A quick one-off question for you.  Is it possible to make a macro that will zero an axis dro from within a gcode program, without moving the axis?
Larry
