Hello Guest it is November 23, 2026, 05:08:57 AM
Author Topic: Mach3, Opt Laser 5W and Aspire  (Read 156996 times)
Offline A11an
  •  62 62
Re: Mach3, Opt Laser 5W and Aspire
« Reply #90 on: February 24, 2021, 12:47:07 PM »
Ok, I'll see what I can do to build a board and come back,
thanks for you time and effort, much appreciated
Allan
Offline A11an
  •  62 62
« Reply #91 on: February 24, 2021, 12:56:04 PM »
Just checking, It says something about Diode lasers using Active High TTL input, is mine?
does it show a different board for that, sorry out of my depth here!
Offline TPS
  •  2,627 2,627
« Reply #92 on: February 24, 2021, 01:15:57 PM »
you are right, sorry to Point you to the wrong circuit.
Offline A11an
  •  62 62
« Reply #93 on: February 24, 2021, 01:24:24 PM »
Just to be sure it's the active high one I need to make?
Offline A11an
  •  62 62
« Reply #94 on: February 24, 2021, 05:05:42 PM »
To be honest I don't understand the schematics drawing or understand how to read the truth table, any help would be really appreciated.
Offline TPS
  •  2,627 2,627
« Reply #95 on: February 24, 2021, 11:28:11 PM »
you have to choose TTL(H) variant.
Offline A11an
  •  62 62
« Reply #96 on: February 25, 2021, 12:20:47 AM »
I just don't understand the drawing schematic of the board
Offline A11an
  •  62 62
« Reply #97 on: February 25, 2021, 02:18:55 AM »
is there any reason the drawing can't be like the attached so an idiot like me can understand?   :)
  •  9,378 9,378
« Reply #98 on: February 25, 2021, 05:09:21 AM »
Hi Allan,
I am sure you are not an idiot but if you need to make one of these boards I can provide you with a circuit diagram although I should perhaps read through your laser manual to determine if such a board is really necessary or not.
I have been using a UC400ETH controller for over a year now but not with Mach3.
Stupid question but have you established that the Mach3 plugin for the UC400ETH does in fact support the M11Px / M10Px command set ?
Offline A11an
  •  62 62
« Reply #99 on: February 25, 2021, 06:05:09 AM »
What do I need to do to find out?
Allan
