Hello Guest it is November 23, 2026, 05:08:55 AM
Author Topic: Mach3, Opt Laser 5W and Aspire  (Read 156994 times)
Offline A11an
  •  62 62
Re: Mach3, Opt Laser 5W and Aspire
« Reply #40 on: February 23, 2021, 07:58:04 AM »
Do you mean bridge while running the gcode?
Offline A11an
  •  62 62
« Reply #41 on: February 23, 2021, 08:13:24 AM »
I've taken some screen shots of settings incase
Offline A11an
  •  62 62
« Reply #42 on: February 23, 2021, 08:15:29 AM »
Spindle
Offline TPS
  •  2,627 2,627
« Reply #43 on: February 23, 2021, 08:15:39 AM »
if you exceute a M3 S200 in MDI line this should Switch on laser with low power,
and if it's on make the Bridge to see what is Happening.
Offline A11an
  •  62 62
« Reply #44 on: February 23, 2021, 08:16:46 AM »
Ports
Offline A11an
  •  62 62
« Reply #45 on: February 23, 2021, 08:24:43 AM »
No it doesn't stop the laser
Offline A11an
  •  62 62
« Reply #46 on: February 23, 2021, 08:37:00 AM »
https://youtu.be/AT_wzEpxEPw
So you can see what it doing
« Last Edit: February 23, 2021, 08:39:40 AM by A11an »
Offline TPS
  •  2,627 2,627
« Reply #47 on: February 23, 2021, 09:06:56 AM »
ok lets try step by step
first test with MDI Input (no Gcode running):
1st Input:       M3 S200         ->this should turn ON laser with low power
2nd Input:       M3 S0         ->this should turn OFF laser
  •  9,378 9,378
« Reply #48 on: February 23, 2021, 09:14:30 AM »
Hi Allan,
This is really not going to work for you with two people making conflicting suggestions.
As I said earlier I leave it all to TPS.
Offline A11an
  •  62 62
« Reply #49 on: February 23, 2021, 09:35:28 AM »
Hi Allan,
Tweakie
I have only made changes you have suggested, I wouldn't change them between conflicting advice, yes I have turned the laser on and bridged the terminals but that's just a test.
Like I've said I appreciate all the help I can get, it's not fair to post a problem on a forum and not let all give advice/ opinions.
Just looking for friendly advice
thanks
Allan
