Hello Guest it is November 23, 2026, 05:09:01 AM
Author Topic: Mach3, Opt Laser 5W and Aspire  (Read 156999 times)
Offline TPS
  •  2,627 2,627
Re: Mach3, Opt Laser 5W and Aspire
« Reply #10 on: February 22, 2021, 06:47:57 AM »
how (Hardware) do you Switch your laser On/off?
scematics would also help.
  •  9,378 9,378
« Reply #11 on: February 22, 2021, 07:02:54 AM »
Your Gcode looks OK.
From your .xml, you are using Output#1 for your spindle M3 /M5 commands and creating a conflict with the M11P1/M10P1 commands.
Change this to Output#2 in Spindle Setup for both M3 and M4 and also Enable Output#2 (set to an unused output pin) in Output Signals.
Hopefully...
Offline A11an
  •  62 62
« Reply #12 on: February 22, 2021, 07:43:32 AM »
Ok, so I don't think I have any spare output pins, should I use the pin 17 as was set in output 1?
Offline A11an
  •  62 62
« Reply #13 on: February 22, 2021, 07:45:37 AM »
Heres the info from OPT Laser ref my board CP0-10V
Offline TPS
  •  2,627 2,627
« Reply #14 on: February 22, 2021, 08:00:00 AM »
and where is the Output witch is switched with M10/M11 wired to?
Offline A11an
  •  62 62
« Reply #15 on: February 22, 2021, 08:02:55 AM »
I'm trying to attach the CP0-10v but the file is too big, hopefully this link will work,
https://cnc4you.co.uk/resources/CP0-10V.pdf
Offline TPS
  •  2,627 2,627
« Reply #16 on: February 22, 2021, 08:13:01 AM »
the 0-10V part is clear, but imho there should be an Output witch is going to the enable Input from laser Interface.
Offline A11an
  •  62 62
« Reply #17 on: February 22, 2021, 08:20:52 AM »
This is where I'm out of my depth! I don't understand how it works, the 2 wires from the CP0-10V go to the Opt laser PLH3D-CNC adaptor into pin 4 & 6, then is it controlled by PWM freq?
Offline TPS
  •  2,627 2,627
« Reply #18 on: February 22, 2021, 09:40:43 AM »
according to this Manual
https://optlasersgrav.com/index.php?controller=attachment&id_attachment=56
i am pretty sure you have to connect an other Output to Enable #1 Input (Pin3),
and this Output is the witch Needs to be switched with M10/M11
Offline A11an
  •  62 62
« Reply #19 on: February 22, 2021, 10:18:17 AM »
Thanks, I'll look at this tomorrow as I'm away from the machine now, I'm not entirely sure how to do that but I'll try to work out
Allan
