Hello Guest it is November 23, 2026, 05:08:54 AM
Author Topic: Mach3, Opt Laser 5W and Aspire  (Read 156993 times)
Offline A11an
  •  62 62
« on: February 22, 2021, 04:36:23 AM »
Hi, I'm still learning but just to make it harder on myself I've installed an OPT Laser on my 3dtek Heavy Mill, I've managed to get it fitted and sort of working but struggling to get the laser to switch on and off, it does trigger on at the start and at the end but continuously on through the burning process. I've installed a post processor in aspire but to be honest I'm struggling to get my head around the whole laser thing. Do I need proper laser software or can I use aspire? I've probably missed a setting somewhere in Mach3, hope someone can help me out
thanks
Allan
  •  9,378 9,378
Re: Mach3, Opt Laser 5W and Aspire
« Reply #1 on: February 22, 2021, 05:02:43 AM »
Hi Allan,
Welcome to the forum.
Mach3 uses the M11Px / M10Px commands (where x is the Output#  selected as your laser trigger) for switching a laser ON/OFF consistent with axis movement.
The Vectric post processor I use is here; https://www.machsupport.com/forum/index.php?topic=36639.0
I use Output#1 for my laser trigger so my commands are M11P1 for turning my laser ON and M10P1 for turning my laser OFF. If you are using a different Output#  then you can use Notepad to modify my post processor to suit your needs.
Hope this helps,
Offline A11an
  •  62 62
« Reply #2 on: February 22, 2021, 05:30:48 AM »
Hi Tweakie
Thanks for the reply, I already downloaded your post processor and I'm using output 1 too, maybe I need to learn a bit more about Aspire and settings in there, I used quick engrave but to honest didn't change any settings. As its not the new laser module Vectrix have where do I find some settings to setup in Aspire?
thanks
Allan
  •  9,378 9,378
« Reply #3 on: February 22, 2021, 05:42:59 AM »
The Aspire Quick Engrave is OK to use, you just need to select the Mach3 laser post processor before saving the toolpath.
Offline A11an
  •  62 62
« Reply #4 on: February 22, 2021, 05:47:47 AM »
Tweakie
Would I have to setup a special tool in quick engrave for the laser to work correctly?
thanks
Allan
  •  9,378 9,378
« Reply #5 on: February 22, 2021, 06:04:47 AM »
Ideally you would create a tool with a diameter equal to your laser spot size but I just select an engraving bit as the current tool (because it has a fine tip size).
(Just checked my Vectric tool table and I have a Laser tool which is 0.2mm Diameter and uses 0.2mm Stepover)
Tool selection would not affect the laser operation.
« Last Edit: February 22, 2021, 06:07:18 AM by Tweakie.CNC »
  •  9,378 9,378
« Reply #6 on: February 22, 2021, 06:09:34 AM »
If you post your .xml file I will check your Mach3 set-up.
Offline A11an
  •  62 62
« Reply #7 on: February 22, 2021, 06:16:37 AM »
Really appreciate the help
Allan
Offline A11an
  •  62 62
« Reply #8 on: February 22, 2021, 06:24:30 AM »
This is a simple file and I think I can see your post processor has worked ok.
Offline A11an
  •  62 62
« Reply #9 on: February 22, 2021, 06:42:15 AM »
No, doesn't make a difference, see attached
Allan
