Hello Guest it is November 23, 2026, 05:08:55 AM
Author Topic: Mach3, Opt Laser 5W and Aspire  (Read 156994 times)
Offline TPS
  •  2,627 2,627
Re: Mach3, Opt Laser 5W and Aspire
« Reply #80 on: February 24, 2021, 12:24:51 PM »
can pin 14 be used where my spindle is usually connected?
Yes.
Offline A11an
  •  62 62
« Reply #81 on: February 24, 2021, 12:26:48 PM »
Do you mean yes but still have to build Tweakies board?
Offline TPS
  •  2,627 2,627
« Reply #82 on: February 24, 2021, 12:28:07 PM »
Yes.
but then you have to use two profiles or Change pin assignment in Config -> Port's and Pin's ->Motor Outputs ->
Spindle.
Offline A11an
  •  62 62
« Reply #83 on: February 24, 2021, 12:28:54 PM »
I am using 2 profiles
Offline A11an
  •  62 62
« Reply #84 on: February 24, 2021, 12:29:40 PM »
For now I don't mind disconnecting the spindle and connecting laser, then maybe build a board
Offline TPS
  •  2,627 2,627
« Reply #85 on: February 24, 2021, 12:29:52 PM »
you have to build tweakies board, because your BOB creates 0-10V and no PWM as far i can see.
Offline A11an
  •  62 62
« Reply #86 on: February 24, 2021, 12:31:34 PM »
I control the spindle speed through mach3?
Offline TPS
  •  2,627 2,627
« Reply #87 on: February 24, 2021, 12:37:10 PM »
yes, but you control it by using the 0-10V Signal, or am i wrong?
Offline A11an
  •  62 62
« Reply #88 on: February 24, 2021, 12:39:20 PM »
Oh yes, sorry
Offline TPS
  •  2,627 2,627
« Reply #89 on: February 24, 2021, 12:39:33 PM »
the plan is to use the PWM Input of your Laser control
