Hello Guest it is November 23, 2026, 05:08:58 AM
Author Topic: Mach3, Opt Laser 5W and Aspire  (Read 156997 times)
Offline A11an
  •  62 62
Re: Mach3, Opt Laser 5W and Aspire
« Reply #70 on: February 24, 2021, 11:47:03 AM »
When I run some gcode I get 4.95v between pin 3 & 4 with it wired pin 8 10k resistor from 5v to pin 8 on bob
Offline TPS
  •  2,627 2,627
« Reply #71 on: February 24, 2021, 11:50:04 AM »
that's like it should be M11P1 is switching Output and Output gives the 5v to Enable Input 1.
so Mach3 and Output are OK, but laser is not turning ON.
Offline A11an
  •  62 62
« Reply #72 on: February 24, 2021, 11:50:47 AM »
so maybe contacting
contact@optlasers.com
would be an Option, for the Moment i can't see, what we are doing wrong.
This is what they said earlier
"Set the adapter back to program 0, then enable inputs are not used. inputs is mostly for advanced use.
This will solv the problem."
Offline A11an
  •  62 62
« Reply #73 on: February 24, 2021, 11:51:30 AM »
Yes
Offline TPS
  •  2,627 2,627
« Reply #74 on: February 24, 2021, 11:54:36 AM »
you can link Terminal 3 (Enable Input 1) to terminal 5 (Enable Input 2), maybe this makes a difference.??
Offline TPS
  •  2,627 2,627
« Reply #75 on: February 24, 2021, 11:58:10 AM »
sorry i overread this, that's bad, because the only way in Mach3 is to use M10/M11 for fast switching laser,
M3/M5 in combination with S-word is to slow and you will allways get burn marks at start and end.
Offline TPS
  •  2,627 2,627
« Reply #76 on: February 24, 2021, 12:00:48 PM »
btw. are you using the relay on your BOB?
Offline A11an
  •  62 62
« Reply #77 on: February 24, 2021, 12:03:12 PM »
Remind me where to check that?
Offline TPS
  •  2,627 2,627
« Reply #78 on: February 24, 2021, 12:09:55 PM »
Forget it, had a look to the layout of your BOB, the NC contact is not connected to a terminal.
a try would be to use a external relay on Pin8 and use this relay to Switch the 0-10V Signal, but im affraid
that the relay switching time will also create burns.
so last Option:
Tweakie has published here: http://www.tweakie.byethost10.com/27_files/Page1020.htm
a small circuit to use PWM and Output for fast switching.
your laser also accepts PWM and you can use Pin 8 and 9 for this.
Offline A11an
  •  62 62
« Reply #79 on: February 24, 2021, 12:19:52 PM »
can pin 14 be used where my spindle is usually connected?
