Hello Guest it is November 04, 2026, 01:57:37 AM
Author Topic: New PlugIn just about done..  (Read 396592 times)
Offline Rimmel
  •  284 284
Re: New PlugIn just about done..
« Reply #170 on: February 12, 2014, 01:14:38 PM »
Not interested in making money, just wanted to see if I could swap the x axis direction.
« Reply #171 on: February 12, 2014, 01:27:45 PM »
sure, just swap the dir sign in the jogging (see the engine->) structure, under the wheel func.
scott
Offline Rimmel
  •  284 284
« Reply #172 on: February 12, 2014, 02:09:26 PM »
That also swaps the keyboard jog and everything else. Just need the shuttle to swap axis.
thanks
« Reply #173 on: February 12, 2014, 02:49:56 PM »
then just change the axis funcs under the funciton call to what you want.
Offline Rimmel
  •  284 284
« Reply #174 on: February 13, 2014, 07:21:48 AM »
? could you explain in a bit more detail please.
« Reply #175 on: February 13, 2014, 08:10:52 AM »
reverse the code in the functions that deal with axis stuff
« Reply #176 on: August 21, 2014, 05:14:53 PM »
I will be getting Mach4 very soon. Does the plugin software run on Mach4? If not, when can this be expected?
« Reply #177 on: August 21, 2014, 08:11:31 PM »
NO,
UNKNOWN..
« Reply #178 on: August 21, 2014, 08:26:57 PM »
OK THANKS A LOT
« Reply #179 on: August 21, 2014, 09:20:50 PM »
You do realize Mach4 doesn't really quite exist yet?  What you can get is a "demo", which is basically a mostly-functional UI.  It will not control a machine.
