Hello Guest it is November 13, 2026, 08:25:17 PM
Author Topic: CS Labs CSMIO/P-A  (Read 410974 times)
Re: CS Labs CSMIO/P-A
« Reply #320 on: September 09, 2018, 04:13:59 PM »
Hi Mick,
kool.
Nice to know they back their gear, of course it would be nicer that it didn't blow in the first place,
but replacing it without question comes a close second.
« Reply #321 on: September 10, 2018, 12:58:27 AM »
Totally agree.
Going back to the spindle debate. What do you think about using 2 X 1.5kw motors on the spindle? Instead of a 3kw 3 phase.
« Reply #322 on: September 10, 2018, 01:47:12 AM »
why?
First: two 1.5kW servo drives which have the same power factor as one 3kW drive will draw the same current.
Second: if the motors were running in torque or velocity mode then its probable you could get them to share the load.
If running a closed position loop then they won't share the load, one servo will always be a few arc minutes ahead (or behind)
its partner and will therefore have to provide the lions share of the effort.
Third: is the price of two 1.5kW servos and drives cheaper than one 3kW servo and drive?. I think the price would favour one large
servo/drive. DO NOT LET THE MISSUS READ THIS OR YOU ARE SUNK!!!
« Reply #323 on: September 10, 2018, 01:20:20 PM »
Hi Craig
I'm not concerned about the power factor.
Can you expand on this?
The price is very similar.
The thing that is bugging me is the phase converter. The company I bought it from are no longer selling these units. They still offer a repair service at the moment but not sure how long for. What I can sell the phase converter for would go a long way to paying for the spindle set up. Old ground but if I wanted to sell the lathe it would be more saleable as a single phase machine. No, I'm not thinking of selling it.
Just exploring and want to make sure I cant use single phase set up before ordering the 3 phase motor and drive.
Mick
« Reply #324 on: September 10, 2018, 03:57:29 PM »
imagine for instance that one servo is mounted 1 degree rotated in its mount relative to its
partner.
When trying to share load when executing an indexed move (position), the leading servo will try to be at 900
at moment t=nnn.nnn and likewise servo 2 will try to be at 900 at the same time. However the leading
servo will actually be at 910 at time t=nnn.nnn. The trailing servo will treat this as the load advancing
on its ideal commanded position and therefore try to retard the leading servo.
This was an artificial construction to illustrate the idea, but any two position servos will inevitably be slightly different
to each other, and if that error differs by more than the 'zero error window' they will fight each other.
In torque they should share equally. In velocity mode imagine one servo is programmed to be a fraction faster than the other.
Which servo powers the load and would not the slower servo be dragging the faster one? There again I have made a
worst case to illustrate the idea but two velocity servos are never going to be identical. What happens to load
sharing then?
Yet!!!
« Reply #325 on: September 10, 2018, 04:16:06 PM »
Hi Craig
Makes sense.
Mick
« Reply #326 on: September 10, 2018, 04:30:46 PM »
if you want 3kW single phase then go Allen Bradley 2098-DSD-030 and matching servo and
be prepared to pay extra for the line reactor/filters.
It is the biggest single phase servo drive I know of.
The only other alternative is to strip the DC link circuitry off a three phase 230V drive and make your own DC llink,
you will almost certainly need buck/boost PFC correction beyond 3 kW but in theory you could make it whatever
 size you want
« Reply #327 on: September 10, 2018, 04:35:35 PM »
Wouldn't be the way I would go (2 motors)  and not sure if your drives support it but if they do then slaving the second drive to the master may work.
Could be called Master/Slave, Electronic Gearing, Master/Follower etc.
« Reply #328 on: September 10, 2018, 04:43:45 PM »
Hi Hood,
master/slave works really well on a gantry say with two ballscrews but Mick is talking about
having two servos locked together on one shaft. I think thats a good way to generate a lot
of expensive smoke.
« Reply #329 on: September 10, 2018, 04:53:15 PM »
I am talking about it being done in the drives rather than Mach, one drive controlled from Mach, the second follows the first by using master/follower mode..
I once messed about with it and the AB drives and it worked well, was sync'ing a live tool to the spindle for cutting Hex etc, can't recall the name of it at the moment, so not the same thing as being proposed here.
As said though it is not a route I would choose, just inviting issues to rear their ugly head.
Edit, Polygon turning was the thing I was trying to remember the name of. Not relevant to this discussion other than I used Follower mode for it.
« Last Edit: September 10, 2018, 05:01:35 PM by Hood »
