Hello Guest it is November 13, 2026, 08:09:45 PM
Author Topic: CS Labs CSMIO/P-A  (Read 410904 times)
Re: CS Labs CSMIO/P-A
« Reply #220 on: August 16, 2018, 01:58:38 PM »
Cheers Craig.
I don't doubt the motors at all after all the discussions ;D ;D.
Just trying to get my head around the encoder wiring to the controller at the moment. It seems I only have T+ T- GND and 5Vdc.
Loads of reading to do.
« Reply #221 on: August 16, 2018, 02:11:17 PM »
that sounds like a serial encoder output. You will not be able to hook that to your CSMIO.
You will instead hook it directly to the drive, it can and will read the encoder signal and as Hood has suggested the drive will synthesize
A+,A-,B+,B-, Z+ and Z- that you can hook to the CSMIO.
« Reply #222 on: August 16, 2018, 02:22:10 PM »
Hi Craig
The encoder does wire straight to the drive. The output to the controller only has four wires. T+ T- Gnd 5vdc. I may be mis understanding the wiring info. Lots of info.
Mick
« Reply #223 on: August 16, 2018, 03:31:18 PM »
Hi
Like I said lots of reading to do. Lol
Ignore the last post I think the output to the controller is on CN1 50 pin plug.
It appears to be on CN1 plug pins 21,22,23,24,25,50 you have A+ A- B+ B- Z+ Z-
Not sure where the GND and 5VDC are coming from though at the moment.
« Reply #224 on: August 16, 2018, 03:51:27 PM »
Am I right in thinking it doesn't need the GND and 5VDC from the controller??
« Reply #225 on: August 16, 2018, 08:16:24 PM »
I suspect the pairs of outputs, A+ and A- for example, are the collector and emitter of a phototransitor respectively.
Thus the switch current will have to be provided by the CSMIO.
« Reply #226 on: August 17, 2018, 12:24:28 AM »
Hi Craig
Thanks. Will have more time to read up over the weekend.
Mick
« Reply #227 on: August 17, 2018, 06:54:08 AM »
I would hope that they would be differential 5V signals, e.g. from a line driver or similar. That would allow a direct connection to the CSMIO. This is the case with my Kinco drives.
If they are photo transistors, some external logic, if only pullup resistors, will be required, which rather messes up the wiring.
Allan
« Reply #228 on: August 17, 2018, 10:05:15 AM »
Hi Allen
Not sure what they are yet. Only got them yesterday and have had chance for a full read. Would you mind taking a look at the manual.
Mick
« Reply #229 on: August 17, 2018, 01:10:56 PM »
Mick
Sorry, with page after page devoted to the spindle drive,  I got a bit muddled as to what you decided to use for the axis. Could you re-post the link for the actual axis drive you have purchased?
Allan
