Hello Guest it is November 17, 2026, 11:04:07 AM
Author Topic: CS Labs CSMIO/P-A  (Read 411648 times)
Re: CS Labs CSMIO/P-A
« Reply #280 on: August 26, 2018, 11:52:04 AM »
Hi Craig
Some of the diagram makes sense but still a little confusing for the laymen. LOL . The CSMIO side makes more sense to me due to having pin numbers I can reference in the manual. Could you detail with pin numbers from the CN1 servo connector?
Hi All
Connected the servo to the drive and am able to jog forward and back at various speeds. Is it possible to test the 0 to 10v analog input?
I have connected the CN1 50 pin plug. I have V-Ref wires to pins 42 and 44 as the manual says.
Set operation mode to V(Velocity)
Set  SPD1 and SPD0 to 0 (Deactivated) The manual states when these two parameters are deactivated the servo uses analogue input.
Set P1-40 to 3000 (Max speed for 10v)
Applying 1.5v to the VREF input but does nothing.
Any idea what other parameters I need to change?
Mick
« Reply #281 on: August 26, 2018, 01:12:39 PM »
Ok making progress.
Had to set parameter p2-10 enable to 0001. (Di1)
Works now. Slight movement without any voltage applied but presume this will be down to turning?
Mick
« Reply #282 on: August 26, 2018, 01:16:43 PM »
meant tuning.
« Reply #283 on: August 26, 2018, 04:00:09 PM »
if you were using the setup software you have a full range of diagnostic test procedures. Note you
will have to be in position mode for the drive to do any positional indexing moves.
Once you go to velocity mode a lot of those procedures are not possible, how the drive software handles
that I don't know.
« Reply #284 on: August 27, 2018, 02:21:37 AM »
Hi Craig
Still waiting for the adapter cable to arrive so having to use the HDI.
Can you please clarify this. I need to understand the wiring diagrams in the manual. I'll just use DI1 as an example.
Example of digital input with internal power supply (logic type 1):
Vdd pin 17 connects to DI1- pin 9 (Through a relay)
COM+ pin 11 connects to COM- pins 47,48 or 49.
Example of digital input (logic type 2) with internal power supply
VDD pin 17 connects to COM+ pin 11
DI1-pin 9  connects to COM- pins 47,48 or 49 (Through a relay)
Mick
« Reply #285 on: August 27, 2018, 02:53:03 AM »
No, that is incorrect. Forget Type1/ Type2 for the moment. The switch contact is more a symbol than actual, no relays here.....relays are for cavemen. Your
'switch' is going to be the phototransistor of the CSMIO. Note that the output cluster of the CSMIO requires a 24V supply and the outputs source current.
Follow the pic attached. 24V supply from the drive (purple highlight) to the output cluster in the CSMIO, output0 of the cluster to the anode of the drive input photodiode,
(orange highlight), and then from the cathode of the photodiode to 0V (pruple highlight).
Don't know what to call it, type1 or type2, better it be Mick's way. If you understand it and it works that's the right way!
« Reply #286 on: August 27, 2018, 03:10:12 AM »
added some pin numbers.
« Reply #287 on: August 27, 2018, 03:18:02 AM »
Hi
Your switch is going to be the phototransistor
I was aware of this, I just wanted to concentrate on the servo side.
Using DI1 as an example.
output0 of the cluster to the anode of the drive input photodiode.
Is this pin 9 or 11?
and then from the cathode of the photodiode to 0V (purple highlight).
Is this pin 45, 47 or 49?
« Reply #288 on: August 27, 2018, 03:26:21 AM »
According to the pic from the manual you attached its pin 9.
Likewise from the same pic the cathode, common to all four DI's, is pin 11 called COM+ and that will be connected to pin 45 or 47 or 49 by an external wire with
your handy soldering iron.
« Reply #289 on: August 27, 2018, 03:33:06 AM »
Thank you
Makes some sort of sense now.LOL
