Hello Guest it is November 13, 2026, 09:09:45 PM
Author Topic: CS Labs CSMIO/P-A  (Read 411200 times)
Re: CS Labs CSMIO/P-A
« Reply #270 on: August 22, 2018, 02:30:50 AM »
Easy enough to solder if your hands are steady and eyesight good. I did mine a few years back and the eyesight was fine but now I may struggle :D
« Reply #271 on: August 22, 2018, 02:34:10 AM »
the origin of these fine pitch plugs was for ribbon cables. Get a plug and crimp the cable in and your done, no soldering.
Next point is that you will not need to populate the whole thing anyway. You'll need 6 wires for the encoder, probably one analogue input,
possibly a couple of digital inputs for enable etc and a couple for error outputs for a total of 11 wires. If you had to solder them....tough get on and
do it.
I seem to recall saying earlier in this thread 'don't overlook the cost of the cables', I know I was surprised how difficult/expensive/time consuming
it was, I rather hoped you could buy all these cables new and no fuss.
« Last Edit: August 22, 2018, 02:37:27 AM by joeaverage »
« Reply #272 on: August 22, 2018, 12:35:37 PM »
Hi
Spoke to technical at Schneider who hadn't got a clue except they were SUB D 50. Said they will have to contact Germany for that sort of info.
Ordered from Rs now. Looking at the plugs Hood linked through the pitch on the solder terminals are 2.5mm so shouldn't be a problem with my 100x magnify glass lens. LOL
Good point Craig regarding the amount of soldering needed. Only need a few connections.
Mick
« Reply #273 on: August 25, 2018, 07:29:11 AM »
Hi All
Got the connectors and back shells. The connector is split into 4 rows of pins with staggered heights which has made soldering much easier.
Here are the links and part numbers just in case anyone reading the topic needs this type of connector.
RS Components:
515-7511
https://uk.rs-online.com/web/p/scsi-connectors/5157511/?sra=pstk
176-2024
https://uk.rs-online.com/web/p/d-sub-connector-backshells/1762024/?sra=pstk
I have soldered the 6 encoder wires,  the 2 VREF wires and digital input 8 (Di8) which de-powers the drive. I was going to wire this to the emergency stop.
I want to wire in another input and output but getting confused with the logic type 1 and logic type 2. There is also an option for using external 24v supply or internal supply.
What would be the better option using the CSMIO?
I have attached a couple of screenshots for ease of reference.
Mick
« Reply #274 on: August 25, 2018, 03:56:29 PM »
do you have a representative circuit diagram for the inputs and outputs of the CSMIO?
The output of the drive is just an isolated phototransistor. If the emitter is connected to 0V then the collector sinks current
whereas if the collector is connected logic high (24V in your case) then the emitter sources current. Easy and flexible.
The choice of which and whether you use the internal supply is going to be determined by the CSMIO, the drive can mange
just about any configuration.
« Reply #275 on: August 25, 2018, 05:28:47 PM »
Hi Craig
Thanks for your response. Yes I do. I will send tomorrow as I need to sleep. This is frying my brain. Too many parameters and options.
« Reply #276 on: August 25, 2018, 07:59:27 PM »
I've downloaded a copy of the CSMIO/IP-A manual.
I would use the 24V power supplies provided within the servo drives.
You have two servos each with its own 24V supply. It is highly likely that they will be the same but if they are not and you connected them together,
that is 0V to 0V and 24V to 24V and they are not identical they could fight each other, I would not recommend it.
I would instead use the 24V supply from one drive to power one of the photo transistor clusters of the CSMIO and use the second 24V from the other drive
to power a second but separate cluster. From page 27 and 28 if you hook the 0V and 24V outputs of one drive to pins 14 and 1 respectively of the DB25
Output connector of the CSMIO then outputs 0-3 of the CSMIO can signal inputs to the drive. In reality you probably only need one, an enable. You
could use others if you were attempting position or velocity indexing but as you are not the will be three unused outputs in that cluster.
With that arrangement the CSMIO output sources current per page 28. That would hook to the anode of the input photodiode of the drive input and the catode
would hook to 0V of its own drive.
In like fashion the 0V and 24V of the second drive would hook to pins 17 and 4 respectively providing supply for outputs 4-7. One of which would be hooked to
the anode of the input photodiode of your selected input of the drive, the cathode would hook to 0V.
Note that the outputs of the CSMIO are current limited but it looks like the current limit is 250mA, rather too much for a photodiode input. Its likely that the photodiode
input has a current limiting resistor in circuit, if not an external resistor will be required. About 5kOhm with a 24V drive will cause an active photodiode current
of about 4mA which should be enough to reliably signal across the opto barrier and still retain a sufficiently low impedance to not be noise prone.
That arrangement allows the outputs of the CSMIO to signal to the drive inputs.
Now consider the reverse. You will want at least one digital output form the drive, a fault signal. You may in fact want more than one. I have not studied
the Lexium manual but I suspect much like my Allen Bradley servo there are a number of fault conditions which can be signaled independently.
Given that you are using the CSMIO to close the position loop then you will not be concerned with a 'following error' fault from the drive. The other
two commonly signaled faults you may wish to handle separately. 'Over current' has a similar meaning to 'following error', when the commanded position
varies widely from the actual position the servo loop attempts to apply a large correction and correspondingly large current. The second fault is 'overvoltage'
which is a the primary indicator that the commanded deceleration exceeds the drives ability to absorb the braking energy. There will be other faults generated by
the drive including overheat and out of limits if so programmed but they are usually combined into one fault output.
I would again make use of the built in 24V supply of the drive. Using Type 1 logic of the previous pic:
connect the phototransitor collector (drive output) to the cathode of the CSMIO input photodiode, IN0-, pin 14, as an example, and the 24V supply of the drive to the anode
IN0+, pin1 per page 23. It would appear that there is a current limit diode in the input circuit of the CSMIO so you need not concern yourself with an external
resistor. You will have to repeat this, ie two wires to each of the CSMIO inputs you require. Make sure that the supply sourcing the output current is returning to the
same supply. That is do not use the X axis drive to supply output current for a Z axis output.
« Reply #277 on: August 25, 2018, 08:03:46 PM »
I may be confusing myself, treat this with suspicion until I think it through or better still come up with a diagram:
« Reply #278 on: August 25, 2018, 09:23:52 PM »
OK, there's Type 1 logic, then there's Type 2 logic and then there's Craig's logic, and while not being partisan at all  ::)
I'll do it my way....
« Reply #279 on: August 26, 2018, 04:06:58 AM »
Hi Craig
Thanks for the details explanation and time again. Will study your diagram this morning and revert back.
Mick
