Hello Guest it is October 23, 2026, 12:03:47 AM
Author Topic: Screen Set Ideas  (Read 471105 times)
Offline smurph
  •  1,575 1,575
Re: Screen Set Ideas
« Reply #30 on: May 25, 2014, 08:11:53 PM »
mc.mcToolPathGetBackColor() has a bad binding.  Thanks for finding that Scott!  It will be in the next update.
Steve
« Reply #31 on: May 26, 2014, 09:22:17 PM »
Hey Steve,
I suspect if there was a bad binding in ONE color func, the others may also be buggy...
Scott
Offline smurph
  •  1,575 1,575
« Reply #32 on: May 26, 2014, 10:24:39 PM »
I found and fixed over 15 of them!  All bad bindings.
Steve
« Reply #33 on: May 27, 2014, 01:35:44 PM »
Did manage to get persistent DRO's to work but it took a lot of coding, hopefully next revision will resolve this issue. My plan this week is to cut some parts with Darwin.
Now write and read variables to the machine.ini file. Write by button, Read by the Load Script
« Last Edit: May 27, 2014, 01:38:17 PM by Ya-Nvr-No »
« Reply #34 on: May 27, 2014, 02:24:12 PM »
Steve
THANK YOU STEVE!!!!!!!!!!!
« Reply #35 on: May 30, 2014, 11:33:27 AM »
Added a start/stop timer and the Screen.set Profile name.
« Reply #36 on: May 30, 2014, 02:41:22 PM »
hummm, who wuda thunk it about putting the screen set name............. :)
scott
« Reply #37 on: May 30, 2014, 03:49:33 PM »
Does that mean that Craig was born in 1955 ??
« Reply #38 on: May 30, 2014, 03:59:34 PM »
Cool stuff !
I also found an early need for the .set name. Had several different screens for different experimental purposes and wanted to know which was loaded as some were very similar.
Mine was not so elegant ... just plopped a dummy button in the corner with a label depicting the screen name. ::)
Craig, I hope you have your screen ready for sale bout the time 4 is released. :)
It must be pretty impressive by now.
Russ
« Reply #39 on: May 30, 2014, 05:42:55 PM »
No Terry few years before that, just when I happened to hit the button good guess thou.
Russ, Ya-Nvr-No I might be ready before them.  ;)
how to get the Screen name (placed in the the PLC script)
you do have to create the text and label on the screen page and give them the correct name.
    ScrName = mc.mcProfileGetString(inst,'Preferences','Screen',ScreenName);  --Screenset name
    scr.SetProperty('lblScreenName', 'Label', ScrName);
« Last Edit: May 31, 2014, 08:14:12 AM by Ya-Nvr-No »
