Hello Guest it is November 13, 2026, 06:35:37 AM
Author Topic: Screen Set Ideas  (Read 480185 times)
Re: Screen Set Ideas
« Reply #290 on: January 24, 2015, 09:09:29 PM »
--set the font size
    UI.ToolTableDialog:SetFont(wx.wxFont(12,0,0,0)) --changes the font to 12
« Last Edit: January 24, 2015, 09:46:14 PM by Ya-Nvr-No »
« Reply #291 on: January 24, 2015, 09:29:25 PM »
OK I found what I did wrong I left in the defaultsize calls and there was a conflict.
Thanks Craig I owe you one, (;-) TP
« Reply #292 on: January 24, 2015, 09:43:21 PM »
I create a header block that has most of the variables, I can then change them all together without searching
local frameCaption = "Wire EDM Cutting Data Chart"
local framePosition = wx.wxPoint(0, 25)
local frameSize = wx.wxSize(1100, 520)
local frameMinSize = wx.wxSize(1190, 920)
local frameMaxSize = wx.wxSize(-1, 1200)
local frameAbout = "About Wire EDM Cutting Data Chart"
local frameQuit = "Quit the program"
local frameStay = "Stay on top toggle"
local frameSetStatusText = "Welcome to Wire EDM Cutting Data Chart Wizard."
local frameMessageBox = " Wire EDM Cutting Data Chart Wizard \n\n"..
                        wxlua.wxLUA_VERSION_STRING.." built with "..wx.wxVERSION_STRING.."\n\n"..
                        "Author: Ya-Nvr-No\nDate created: 12/26/2014\nDate modified: 01/18/2015\n\n"..
                        "Reads & Writes to an excel.csv file"
local CSVFilename = "C://Mach4Hobby//Wizards//CSV//wire_edm_cutting_data.csv"
« Last Edit: January 24, 2015, 09:49:58 PM by Ya-Nvr-No »
« Reply #293 on: January 24, 2015, 11:18:37 PM »
Well I thought I had it BUT it will only go to about 3/4 screen size and that is it. No matter what settings I try. So there is something else hanging it up and keeping it from expanding full size.
« Reply #294 on: January 24, 2015, 11:51:11 PM »
OK I found the problem. FINALLY
YOU HAVE to include a MIN and a MAX size to the box. all I had was a MAX.
OK Now the next thing to try and do is to create a BUTTON to do an OPTIONAL sort of the tool table based on DIAMETER and have it Smallest to largest order.
« Reply #295 on: January 25, 2015, 05:23:43 AM »
Based on that your working with the Industrial Version, looks like your committed to learn mach4 and Lua  :D
I'd posted a sorting routine I created, thou I think you will have to sort the whole tool table data, so your not just sorting one field but an associated multi fielded array. And also check for the field value above zero or all you data will be at the bottom of the table based on smallest to largest diameter.
« Reply #296 on: January 25, 2015, 12:06:55 PM »
Committed like the pig for breakfast bacon. ;D
Yes I understand when I sort it sorts the whole table but based on the Diam Field and reading smallest to largest.
With a LARGE tooltable (100+) you have to be able to FIND what you need, not spend time searching for it.
Another question on BUTTONS. I can put then LEFT CENTER RIGHT but NOT all on the same line. Any ideas??
I'll look for your sort code. >:D
« Reply #297 on: January 25, 2015, 01:51:56 PM »
Put them in a button sizer
« Reply #298 on: January 25, 2015, 03:53:09 PM »
HIYA Scott I did use a Button sizer for all three. BUT I cannot figure out to place them all on the same PLANE in the dialog box. I can do L,C,R but they end up on 3 different levels in the box.
Left
           Center
                           RIght
Instead of
Left      Center     Right
« Last Edit: January 25, 2015, 04:05:08 PM by BR549 »
« Reply #299 on: January 25, 2015, 04:01:03 PM »
Here is the example code I am working with.
