Hello Guest it is November 22, 2026, 12:42:03 PM
Author Topic: Screen Set Ideas  (Read 481709 times)
Re: Screen Set Ideas
« Reply #50 on: June 02, 2014, 03:05:03 PM »
OK right out of the Fanuc manual, you can create and  use a M60 if you want but I am going to let the Control do all the work(;-)
Param#  0040.3 = 1   (disables M2/M30 counting)
Param#  0219    = 99 (M code for counting # of parts, 0=not used)
The Part Counter #var may also vary with Models of the control
You can also turn BOTH on for a single cycle part count.
QUACK QUACK, (;-) TP
« Last Edit: June 02, 2014, 03:08:23 PM by BR549 »
« Reply #51 on: June 02, 2014, 03:13:23 PM »
your getting the idea
fanuc is full of quack quacks
now we have mach4 a new duck
I can create my own M7734 for what ever in fanuc
ladder dont care
ya just have to have access to it.  >:D
« Last Edit: June 02, 2014, 03:18:54 PM by Ya-Nvr-No »
« Reply #52 on: June 02, 2014, 04:01:58 PM »
NO , YOU have a new duck. as soon as this TEST experiment is over I go back to the PIG PEN where I belong. All this Game Boy programming makes my head hurt and burns up WAY TOO MUCH TIME. I have parts to make and chips to sling, Beads to weld and pretty Metal Metal  art work to cut.
NOW IF you get tired of the Fanuc QUACK there is always HAAS. A very much IMPROVED Fanuc(;-) Probaly more of a TWEET TWEET
OWINK OWNIK , (;-) TP
« Last Edit: June 02, 2014, 04:05:23 PM by BR549 »
« Reply #53 on: June 02, 2014, 04:17:51 PM »
IS there a way in the SCREEN to set the {TAB} ORDER of each page,box,etc. Right NOW the screen is NOT {TAB} friendly.
Just trying make the screen keyboard friendly for the NO MOUSE users. (Yes that is ME as well)
If it has a mouse(PC) leave it at the house.
« Reply #54 on: June 02, 2014, 04:27:33 PM »
OK never mind that question.
 Mach4 does NOT even do {TAB} to the object (button) and {ENTER} to DO. IT is mouse or nothing .  :'(
« Reply #55 on: June 02, 2014, 05:19:43 PM »
I've worked on HAAS MC and TC too, lot more bells and whistles. Same smelly coolant and way lube. Just a lot prettier screen set with more to play with.
« Reply #56 on: June 02, 2014, 09:36:35 PM »
Added ms timer & Date and Time parameter values
« Reply #57 on: June 02, 2014, 09:53:35 PM »
NOW if you can create the CURRENT TIME and DAY and DATE I would know when to go take my coffee break  (;-) AND verify it wasn't Saturday.
Good Job, (;-) TP
« Reply #58 on: June 02, 2014, 10:03:18 PM »
That is the time and date calculated from the pound variable #3011 show in real time as does the ms timer. Use a push button to start and stop. I added a second button for cumulative times.
So you can see how long you were on that nap you call a coffee break   :D
« Reply #59 on: June 02, 2014, 10:59:12 PM »
You really expect me to be able to SEE that. I need a FULL page display WITH very large FONT.  I did have a TOOL change blinkin page with Mach3 one time it was a FULL page LED blinking. I could see it across the shop. Every one knew it as the One Eyed Blinky Monster.
Took too much teasing over that one HAD to take it OFF.
