Hello Guest it is November 22, 2026, 12:42:01 PM
Author Topic: Screen Set Ideas  (Read 481708 times)
Re: Screen Set Ideas
« Reply #170 on: November 13, 2014, 08:36:48 PM »
not much other than mach4 does not support encoders other than use the signals from a MPG dial and Art called them encoders in Darwin.
« Reply #171 on: November 14, 2014, 11:08:28 AM »
Ya-Nvr-No,
How do you configure the MPGs?
Peter
« Reply #172 on: November 14, 2014, 12:05:08 PM »
I did them with function calls, I just pass the data from the button to a common function.
but this is basically what you need to set
    joginc = mc.mcJogGetInc(inst,0); -- get the present increment
    mc.mcMpgSetAxis(inst, encoderid, axisid); --mpg encoder , axis ;  encoder 0, X axis 0
    mc.mcMpgSetAccel(inst, encoderid, 15); -- 15%
    mc.mcMpgSetRate(inst, encoderid, 100); --100
    mc.mcMpgSetCountsPerDetent(inst, encoderid, 1); --one click give one incremental step
    mc.mcMpgSetInc(inst, encoderid, joginc); -- pass the increments from the MPG encoder steps
« Reply #173 on: November 14, 2014, 03:18:19 PM »
Where are these function calls listed/documented?
Peter
« Reply #174 on: November 14, 2014, 04:56:28 PM »
If you start typing mc.mcMpg you get a whole list of functions to choose from on a drop down list. All started from some scatted files created and shared. I spent hours copying and pasting what popped up when I started the wx.wx list. And then LOTs & LOTs of trial & error to start to grasp how to use Lua. There is scattered tidbits of info all over the mach4 forum section. And my understanding is they are working on a reference doc.
http://www.machsupport.com/forum/index.php/topic,27141.0.html
« Reply #175 on: November 14, 2014, 06:59:25 PM »
Ya-Nvr-No,
Thanks for the drop down hint, that'll help tremendously.  How did you get the argument lists?  None of these are in the reference doc that I can find.
I fully expect that learning how to write scripts for Mach 4 is either going to keep me out of the bars or in them.  I've learned a few programming languages this way and greatly appreciate any help in getting started.  Just getting to the point of writing and executing the first script can be intense.  A "Hello World" example for Mach 4 might help a lot of people get started.
Peter
« Reply #176 on: November 14, 2014, 08:13:13 PM »
Brian had provided a wizzard to use the mouse scroll wheel as a MPG so I picked up a lot in that example, sorry not sure where its at as I did a search but cant find it.
« Reply #177 on: November 14, 2014, 08:59:53 PM »
Ah hah, a mouse wheel.  That explains a lot to me!  Well, Mach 4 won't be soup until long after MPG support is incorporated.
Maybe I should spend my time trying to fix the homing routine instead.
Thanks for your help.
Peter
« Reply #178 on: November 14, 2014, 09:32:24 PM »
Found this video, which has a link to the script:
https://www.youtube.com/watch?v=MRyaRQwhYWk
« Reply #179 on: November 15, 2014, 05:36:17 AM »
Thanks Gerry
I knew it was not lost, but I sure don't remember getting it from there.   :-[ Hell to get old.
I included the folder link. Hopefully Brian will add to it soon with other cool features
ftp://machsupport.com/Mach4_Lua_Scripts/Panel_Scripts/
« Last Edit: November 15, 2014, 05:57:34 AM by Ya-Nvr-No »
