Hello Guest it is October 22, 2026, 11:15:15 PM
Author Topic: Screen Set Ideas  (Read 471075 times)
Re: Screen Set Ideas
« Reply #190 on: November 24, 2014, 09:40:31 PM »
Started working on my laser screen set
Hopefully I can use the B axis as a Z' for the focus control.
« Reply #191 on: November 30, 2014, 10:44:35 PM »
Spent some time on the probing screen and routines today. Uses variables for the various gcode files called.
« Last Edit: November 30, 2014, 11:25:01 PM by Ya-Nvr-No »
« Reply #192 on: November 30, 2014, 11:01:00 PM »
HIYA Craig, You need a Probe test LED on screen AND a probe # DRO to tell you which Probe to use. Maybe an exterior and interior probing array ?? or maybe a creepy crawl routine for profiling
Just a thought, TP
« Reply #193 on: November 30, 2014, 11:10:03 PM »
the led is there, only have one probe , The buttons on the left are for interior and exterior probing.
And if you can write the routine in macro B, gcode or Lua go for it. This is just a start for my needs long time before it will every be fully completed as the more I learn the more I can add to my screen set.
« Reply #194 on: November 30, 2014, 11:10:49 PM »
Just a thought but do you know IF G31 on an arc was implimented ????
« Reply #195 on: November 30, 2014, 11:11:56 PM »
Looking Good, (;-) TP
« Reply #196 on: November 30, 2014, 11:13:38 PM »
your "Mach4 Alpha" I'm just learning how to use it for my needs.
Offline dude1
  •  1,253 1,253
« Reply #197 on: November 30, 2014, 11:42:24 PM »
good reply Ya-Nvr-No
a request that's up to when M4 is finely realised can you shear your screen sets or sale them
« Reply #198 on: December 01, 2014, 09:06:13 AM »
Hiya Craig NOTHING ALPHA about me. I do not belong to the inner circle (;-) I am still running on the demo.
I did find some code to build a Simple calculator in Lua.
« Reply #199 on: December 01, 2014, 09:12:32 AM »
Just so you all know how these variables are passed from a screen DRO to a #variable that the gcode can read and use:
again placed in the plc script, it sees the values and passes them to the pound variable holding registers. Each has its own name and variable associated to it
local valPartDiameter = scr.GetProperty('droPartDiameter', 'Value');
mc.mcCntlSetPoundVar(inst, 200, tonumber(valPartDiameter));
daniellyall: have to give your credit for trying as you've posted several times that your loving what you see, Thanks  ;D
Here is a code snippet (modified from an original probe routine) for probing a hole:
Code: [Select]
g61
#98 = 20 (Rough probe speed)
#97 = 3 (Fine probe speed)
([#200] diameter of circle)
([#203] Probe X Travel distance)
([#204] Probe Y Travel  distance)
([#206] Retract distance)
g91
g01 z0.0
g31 y-[#200] f#98 (Rough probe for -Y Pos)
g01 y[#206]
g4p1
g31 y-[#204] f#97 (Fine probe for -Y Pos)
#102 = #5062
g0 y[#206]
g4p1
And now, just noticed that I need to make the feed rates also a passable feature. (You see how this is never ending)  ???
and not sure just why I need a dwell using the ESS but I hope that will be addressed and I can remove them.
