Hello Guest it is October 25, 2026, 12:47:33 AM
Author Topic: JY5300 AND JY800W AND MACH3  (Read 118574 times)
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: JY5300 AND JY800W AND MACH3
« Reply #20 on: May 05, 2013, 06:15:22 AM »
time to post your xml again then please.
« Reply #21 on: May 05, 2013, 06:35:43 AM »
OK
Thank you for your time much appreciated.
I just tried it all again ( I'm flipped out my self) no go.
Time for a coffee then I will go back to the shop and get it.
« Reply #22 on: May 05, 2013, 07:28:51 AM »
this may be a dupe sorry
here is the xml
Offline stirling
  •  2,188 2,188
  • UK
« Reply #23 on: May 05, 2013, 08:30:33 AM »
OK there are several things to change or check.
Motor Outputs:
1) you have the spindle enabled with its step and dir pin set to pin2 of port zero. I suggest you disable this for now. We can sort your spindle later.
Input Signals:
1) Do you actually have limit switches on your machine? if YES then OK else disable the limits.
2) You have the E-Stop Emulated. Untick Emulated. If this solves the E-Stop problem OK else untick active low.
3) You have OEM Trig #1 set to the same pin as E-Stop. Disable OEM Trig #1
Output Signals:
1) You have the charge pump set to port 1 pin 1. Does your system need this?
Ian
« Reply #24 on: May 05, 2013, 08:43:33 AM »
wow
I have a water cooling in spindle motor ? not sure I need pump
as it pump runs with out PC
I will change it.
Yes I have 6 limit switches all work 2 for each axis,
Great will try all this now
Thank you
« Reply #25 on: May 05, 2013, 10:06:28 AM »
OK
I did what you said please take a look.
No progress?
first one was X you have
Second one is Y
Offline stirling
  •  2,188 2,188
  • UK
« Reply #26 on: May 05, 2013, 10:58:34 AM »
do you get this? (see attached image)
« Reply #27 on: May 05, 2013, 11:10:46 AM »
I did not have the machine connected so am I getting a false reading.
I will try it with the machine on and off
Thank you
Offline stirling
  •  2,188 2,188
  • UK
« Reply #28 on: May 05, 2013, 11:17:06 AM »
You don't have the machine connected?
...AND it would appear the forum doesn't have a smiley icon to show me banging my head on the (flipping) desk.
« Reply #29 on: May 05, 2013, 11:48:12 AM »
I did try it with it with the machine on and off it makes no difference. I still get the  same reset button flashing.
Pray tell me do you need the machine on to up software.
I thought you setup the software and then turn on the machine and try it.
So now what
