Hello Guest it is October 17, 2026, 07:28:41 PM
Author Topic: Impact engraving plugin  (Read 881353 times)
  •  9,374 9,374
Re: Impact engraving plugin
« Reply #120 on: April 01, 2011, 06:33:04 AM »
So it seems that it is completing the image (half width) in one direction then continuing to the end of the current line then completing another half width image on the return.
Sorry, but I really have run out of suggestions on this one, perhaps Art may check this thread and know the answer but it has certainly got me baffled.
Anyone else following this thread have any suggestions ?
Offline obal
  •  14 14
« Reply #121 on: April 01, 2011, 08:01:56 AM »
Hi
You have old model plugin
Its my plugin OK.   http://www.machsupport.com/forum/index.php/topic,16446.40.html
Hi, I tried, but the problem is the same.
« Reply #122 on: April 01, 2011, 08:15:53 AM »
   my plugin is 2.00.075.
  •  9,374 9,374
« Reply #123 on: April 01, 2011, 11:04:54 AM »
My plugin is 2.00.075 also.
« Reply #124 on: April 01, 2011, 11:08:14 AM »
Everything works.
It should not be activated 1 / 2 Pusl.
Now I can buy the license ....
I hope it can also be used for others ..
Thank you all.
  •  9,374 9,374
« Reply #125 on: April 01, 2011, 11:15:05 AM »
Brilliant Andrea.
You have just become the resident expert on this plugin  ;D ;D
Offline obal
  •  14 14
« Reply #126 on: April 02, 2011, 12:38:36 AM »
Yes ! Wery good Job. My machine not activate 1/2 pulse = work OK.  Super.
Everything works.
Thank you all.
« Reply #127 on: April 02, 2011, 04:09:59 PM »
Hi to all.Laser 78 I was facing the same problem.You saved me .Thanks
« Reply #128 on: April 04, 2011, 04:46:49 AM »
Hello.Finally the solution that laser 78 proposed didnt work with me.I was facing exactly the same problem .Any ideas what it might be the fault? ???
« Reply #129 on: April 04, 2011, 04:50:37 AM »
Laser 78 , can you post your configuration?Thanks
