Hello Guest it is October 17, 2026, 06:48:38 PM
Author Topic: Impact engraving plugin  (Read 881333 times)
Re: Impact engraving plugin
« Reply #340 on: January 30, 2017, 11:40:21 AM »
any body is here to be send plugin TOMTOM Tomura Kazuki for me?!! :'( :(
« Reply #341 on: January 30, 2017, 11:49:20 AM »
Will talk to him and ask if he allows
« Reply #342 on: January 30, 2017, 01:05:51 PM »
i sent for him Massage but he dont answer me yet.
« Reply #343 on: February 03, 2017, 06:46:22 AM »
Hi Jan,
Do you have a photo of your impact head, or a drawing showing the construction? Could you share if so please?
May be I still don't fully understand your construction as I don't see why using magnets would be preferable over a spring?
« Reply #344 on: February 05, 2017, 08:35:23 AM »
The reaction time of the magnets should be much higher than a mechanical spring. Plus they never wear out of change stiffness as the temperature changes within reason.
Mike
« Reply #345 on: February 13, 2017, 03:57:36 PM »
Dan, just take a look at a tatoo drawer, it´s exactly where i took my idea, and afterwards I took of the spring and used magnets. there is a coil(electric) on one end, and is sided by two powerfull neodimium magnets, this gives the movement, in the oher side , before the diamond tip i had a spring, now i have 4 smaller neodimium magnets, that always repels themselves.I pluged the coil in a stepper driver , shutting both a+ and B+ in one side and both a- and b- in the other wire , i shuted (jumped) both dir and step inputs on the s' or digital trigger from the board to the step driver , this will be the same as a laser ttl+ and ttl-.
In the compiling make the signal be more than 90 ms , or you won´t have impact, but a noise.
Hi, it will depend of what kind of hardware you are using, the best I could achieve was using a l298 and a dc-dc step down.
The thing is that the digital trigger from Mach3 must be conected together in step and dir of the l298.
don´t worry about english, I'm from Brasil and my english is terrible!
I am now triyng to find a different approach , instead of just using digital trigger, i am tryng to combine it with the pwm signal using  the attached software to generate the  g-code,
Give it a try , you can choose between S or Z generation , one will be used on digital trigger the other can be used to engrave slowly and with z .
The soft is in brazillian portuguese
See this scheme , maybe will help you.
Yes...it is paint ,lol.
Hi, great work, I am very interested at this application, I have read all the messages but I am not sure if the connections are right for mach3, but i have not any idea how to connect the wires if I want to use Arduino Uno R.3. Other thing that I don't find are the number of stepps for mm. that I must write in the configuration in mach3 and for Arduino Uno.  I use on my cnc  a board 4 axis all in one based on L298 with a voltage of 45 VDC (https://shop.strato.de/epages/61125483.sf/de_DE/?ObjectPath=/Shops/61125483/Products/%22SM44PCV5.2/RK2%22) but if I want use this application I must detach the fourth axe and to use an external bridge for the coil (max 24 Vdc) or I may use the two bridges based on  TB6560 that I have made for another little cnc to use Arduino Uno.
Other thing that I don't understand is how to build all the system for the impact because it isn't clear how to install the magnets and especially the coil. I hope that you help me.
I enclose a photo with the connections to know if they are right for mach3.
Claudio.
« Reply #346 on: February 14, 2017, 03:29:43 AM »
Another thing that I would know it is how to set the driver L298 and TB6560 in full step, half or other.
Claudio.
« Reply #347 on: February 14, 2017, 04:17:46 AM »
Cláudio..mach3 will work with arduino through modbus.
Tis a little more complicated.Go with paralel port if you are not a sénior user.
Plus the concept of magnets is not so easy arranged Like that.the 298 should work bit you need a dc-DC step down. Send me a e-mail tonight i will be answering them
« Reply #348 on: February 23, 2017, 02:37:19 PM »
Hi . Can help me anybody with a new and working engraving.dll?
Thank you!
« Reply #349 on: February 24, 2017, 10:54:30 AM »
Hi there,
I've got a question. Whenever I start engraving, the machine engraves it in italic shape not straight! Does anyone know what's the problem with?
