Hello Guest it is October 17, 2026, 07:29:08 PM
Author Topic: Impact engraving plugin  (Read 881359 times)
  •  9,374 9,374
Re: Impact engraving plugin
« Reply #60 on: December 22, 2010, 12:59:29 AM »
Stitos,
It is a short duration pulse (40uS for laser) but it is the pulse repetition frequency (0 to 100%) that varies. Obviously Art would be able to provide a better description but this is the type of signal that I see.
  •  9,374 9,374
« Reply #61 on: December 22, 2010, 01:01:40 AM »
Andrea,
Excellent work, as always, on your completed impact engraving unit, extremely professional. (hope you sell lots  ;) )
« Reply #62 on: December 22, 2010, 02:48:24 AM »
But the voltage and intensity of LPT1 is modified or not?
  •  9,374 9,374
« Reply #63 on: December 22, 2010, 03:09:45 AM »
Stitos,
Sorry my explanation was not very good, I will try again.
The voltage on the selected LPT1 pin (digital trigger) is, in my case, either 0V or 5V (off / on) It is pulsed for a duration of 40uS at a varying frequency which is dependent on the image depth and the axis feedrate.
This produces the equivalent to a variable duty cycle (similar in it's effect to 'Pulse Width Modulation') but it is essentially Pulse Repetition Frequency (PRF).
Hope this helps.
« Reply #64 on: December 29, 2010, 05:55:29 PM »
This driver based in L298N.
Can it work? For impact engraving pluging.
how connect the signals? ???
  •  9,374 9,374
« Reply #65 on: December 30, 2010, 02:28:51 AM »
Stitos,
As far as I can tell,
the electromagnet should be connected across outputs 'out-a' and 'out-b'.
'en1' (en-a) should be held high (10k to +5 Volts).
input would be on 'in-a' or 'in-b' (either one will do).
other inputs are unused.
« Reply #66 on: December 31, 2010, 06:15:49 AM »
Hi Stitos,
This is the schematics that I use and works very well.
You can connect magnet on A1 and A2.
Andrea
--  I am sorry for my bad English, I hope I never say the wrong things  --
« Reply #67 on: December 31, 2010, 06:21:27 AM »
Hi Sitos,
And this is the link for the datasheet...
http://www.robotfactory.it/CncDatasheet/L6208.zip
http://www.robotfactory.it/CncDatasheet/AN1451.zip
http://www.robotfactory.it/CncDatasheet/AN1495.zip
If you want I give you the PCB design in Eagle.
Andrea
« Reply #68 on: December 31, 2010, 06:33:24 AM »
Hi Sitos,
And this is the layout, connections and registration...
Andrea
« Reply #69 on: January 02, 2011, 12:48:45 PM »
Hello,
Not work my driver,   ET SMMC V2.0    (L298N
