Hello Guest it is September 27, 2026, 08:57:18 AM
Author Topic: AL54b (lathe) project from New Zealand  (Read 704159 times)
Re: AL54b (lathe) project from New Zealand
« Reply #250 on: April 23, 2015, 12:02:35 AM »
In Config /Ports&Pins you will need to use the settings in Spindle / motor control and special functions. I think you have dealt with these already.
Done
In General Config at top right hand corner you have Input Signal debouncing. For Index Debounce you may need a value of 0. I do.
Done (default is 0)
Under Pulleys you need to set the RIGHT ratio, and you need to calibrate the Z axis (lathe) correctly as well.
Done
OK, you seem to be threading OK; you just need to get the pitch right.
Correct
Um - just checking: you have only ONE index pulse per rev, yes?
Correct
Roger
Offline rcaffin
  •  1,073 1,073
« Reply #251 on: April 23, 2015, 01:34:05 AM »
Hum ....
What feed and speed are you using?
Roger
« Reply #252 on: April 23, 2015, 03:41:22 AM »
200-400 rpm .2 per pass, threads look good, the pitch is wrong
Offline rcaffin
  •  1,073 1,073
« Reply #253 on: April 23, 2015, 05:41:32 PM »
Steel, brass, aluminium?
Belabouring the obvious, but perhaps you could run a quick check over the Z feed calibration and the RPM once more. There has got to be an error somewhere, as I routinely thread accurately with Mach3 myself.
« Reply #254 on: April 23, 2015, 08:23:08 PM »
Ali 20mm stock 1.5mm pitch been playing with 2mm as well.
Z axis is accurate, am thinking about how to check the RPM still, ideas are welcome
Offline rcaffin
  •  1,073 1,073
« Reply #255 on: April 24, 2015, 12:24:57 AM »
I have noticed on my machine that even with my best efforts, commanded RPM and actual RPM, as displayed by Mach, are not always exactly the same... The (Mach) displayed speed should be fairly accurate.
I did eventually use the Mach spindle linearisation routine in one of the menus to improve that.
Roger
« Reply #256 on: April 25, 2015, 01:25:48 AM »
I just cut the best 1.75mm tread I have ever cut in my life! I rand the same Gcode over and over again, after the first run I never saw chips again, it is perfect.
Same problem, had to set the pitch to 4mm to get the 1.75mm thread.
Can anyone tell me:
1. are you using the default mach3 wizard?
2. are you using imperial or metric as your default setting?
3. are you able to cut metric threads with the wizard?
I'm off to the Marshal Islands for a couple of weeks so wont be able to test anything but would appreciate the help all the same.
cheers
« Reply #257 on: April 25, 2015, 01:27:26 AM »
Roger
I don't think this matters so much, from what Ive read mach will adjust the Z feed based on what it is picking up from the spindle true pulses anyhow.
Offline rcaffin
  •  1,073 1,073
« Reply #258 on: April 25, 2015, 01:34:25 AM »
True, quite true.
I just wanted my machine to be a bit more 'linear'.
I have used the wizard; the rest of the time I hand code. Both work for me.
METRIC
Yes.
In general I don't use imperial at all.
A ratio of 4:1.75 (or 16:7) is really wierd!
Roger
« Reply #259 on: May 10, 2015, 04:39:44 PM »
baring figuring out what thread pitch to put in with a ratio to cut it right I am officially out of ideas.
