Hello Guest it is November 12, 2026, 02:24:01 PM
Author Topic: AL54b (lathe) project from New Zealand  (Read 712606 times)
Re: AL54b (lathe) project from New Zealand
« Reply #170 on: February 19, 2011, 03:57:47 AM »
JRSLICK22,
May want to consider what i did for covering the screw on my converted Atlas lathe.
Works great and was better than usiing a shower curtain rod cover.  ;)
« Last Edit: February 19, 2011, 04:05:34 AM by RICH »
Offline rcaffin
  •  1,073 1,073
« Reply #171 on: February 19, 2011, 04:45:28 AM »
Neat idea.
Aluminium? That tends to scuff and wear a bit normally.
Some shim SS or brass would look awful neat though ...
« Reply #172 on: February 19, 2011, 09:21:43 AM »
Nice days work.  Sometimes when you step back for a couple days, you redo things ....  Evolution of the lathe, can't wait to see the chips flying.
JH
« Reply #173 on: February 24, 2011, 11:18:31 PM »
I got the belt today and mounted the motor, all indicators seem good, sprocket is just for hand cranking the axis for testing.
Spent a little time getting her plumbed up also:
« Reply #174 on: February 25, 2011, 04:24:37 AM »
Looking good :)
Only comment I would make is copper pipe may be better if its anywhere near where hot swarf may be.
« Reply #175 on: April 11, 2011, 04:11:59 PM »
Z Motor mount is all done, i haven't had a lot of time as of late but i am still trying to make progress on this project.
« Reply #176 on: April 14, 2011, 05:43:07 AM »
WOW!
What a fantastic job. I am halfway through a CNC conversion on this same lathe, but my enclosure is no where near as great as that one. I'm a total nube when it comes to this stuff and I am glad I have found this thread. Keep up the great work.
« Reply #177 on: April 14, 2011, 05:57:51 AM »
Please start a threat id love to see your machine.
« Reply #178 on: April 14, 2011, 04:06:36 PM »
I got the Z axiz nut mount cut out and mounted tonight.
from the front:
and the back:
I even went as far as hooking the step motors up to my mills 4th axis (mill runs servos on the other axis), so i guess......its alive!
cheers
Offline rcaffin
  •  1,073 1,073
« Reply #179 on: April 14, 2011, 04:38:25 PM »
Looks very neat.
I have a tiny concern about the rigidity of that mount though. The ball screw is a long way (so to speak) from the friction on the bed. The original had a rack attached much closer to the bed.  I would think about adding a little bit of reinforcing to the plate but parallel to the bed myself, but I may be fretting too much.
Unless, of course, you could move the ball screw a lot closer to the surface of the bed?
