Hello Guest it is November 12, 2026, 02:24:07 PM
Author Topic: AL54b (lathe) project from New Zealand  (Read 712607 times)
Re: AL54b (lathe) project from New Zealand
« Reply #230 on: May 05, 2012, 12:43:08 AM »
Wow,
I'm humbled to read that I've been an inspiration to others with my 'over-the-top' mill conversion!
I'm just a guy who can't leave things alone once I get started tinkering with them.
Anyway, very nice looking work on the lathe & I really like your take on the chip pan for the mill ..
I've discovered that once wet, chips do tend to stick so I've plumbed a wash down hose to clean up after I finish a job.
Your chip pan would be absolutely PERFECT for that kind of application .. keep up the good work!
gd.marsh
Yeah dude your machine build really lit a fire in me to get my machine finished, jhchoppers the same, what set all of this off was your belt drive conversion, so easy to do!
My machine used to max out at 1200rpm now I get about 7500rpm and she loves Ali.
I have also followed suit with your auger idea, I have it all bolted up just need to mount the motor and try it, I sure hope it works.
So yeah thaks GD, your machine is awesome!
Offline kooka
  •  12 12
« Reply #231 on: November 10, 2012, 10:56:10 PM »
gday jrslick,  really enjoyed and been inspired by reading your builds especially as i have the same lathe already fitted with vsd and about to tackle cnc conversion. very interested to know how your builds/machines are going?
« Reply #232 on: November 11, 2012, 02:15:27 PM »
The machine has been in bits waiting for paint for months and months, i have been doing little bits and pieces as i have had the time but nothing significant.
Offline rcaffin
  •  1,073 1,073
« Reply #233 on: November 11, 2012, 02:22:40 PM »
Wonder what RPM the bearings are rated for?
« Reply #234 on: November 11, 2012, 02:44:34 PM »
Ive replaced em already see the G.D.Marsh thread
« Reply #235 on: June 24, 2013, 11:02:09 PM »
I got my steppers from http://www.homanndesigns.com/store/index.php?main_page=index&cPath=25 i used the 269 for the X and the 287 for the Z with 1:1 timing pulleys, it does 3.5mps on rapids (speed was important)
Hope this helps
just a quick question , I too am looking at a pulley set up for a mill I am building, my question is your pulley ratio is quoted at 1:1 whats the advantage? (other than space)
Adrian
« Reply #236 on: July 02, 2013, 04:54:15 PM »
It allows you to offset the motor for clearance, if possible i prefer the direct couple option.
« Reply #237 on: April 04, 2015, 01:56:24 AM »
The server i kept all of my images on has been moved/shutdown, I have uploaded them all to photobucket instead, does anyone know how I can edit the posts with the new image addresses?
cheers
Offline rcaffin
  •  1,073 1,073
« Reply #238 on: April 04, 2015, 02:25:13 AM »
Can't be done after this sort of delay. Contact the mods instead.
Roger
  •  9,377 9,377
« Reply #239 on: April 04, 2015, 02:47:26 AM »
cheers
Hi JR,
If you do all the hard work of detailing which post and which image address and the order of those new images I will drop them in for you.  ;)
(you could PM or e-mail me with the details).
