Hello Guest it is November 12, 2026, 02:35:36 PM
Author Topic: AL54b (lathe) project from New Zealand  (Read 712610 times)
Re: AL54b (lathe) project from New Zealand
« Reply #130 on: December 11, 2010, 08:09:59 AM »
Nice fab work as always.
JH
« Reply #131 on: December 13, 2010, 11:22:01 PM »
My ball screws turned up :) the short one 350mm is only 15.2mm not the described 16mm so the nut that i ground for the x slide don't fit :(
Nothing quite like waiting 4 weeks for a part that don't fit.
Ive had a hard couple of days at work so haven't had time to work on the lathe, hoping to get more time on Thursday.
« Reply #132 on: December 14, 2010, 12:41:58 AM »
That's bad news, maybe a smaller nut will fit better in the confined space you're working with.
Phil
« Reply #133 on: December 14, 2010, 05:38:57 AM »
I got my Nine9 Engraving tool in the mail about a week back, my mill has been out of auction so i havnt had the change to have a play.
Here is the tool:
My first time engraving so ran it real slow and easy:
F100 X&Y F50 Z
got sick of waiting for it, F200 X&Y F100 Z
lessons learned:
Work must be perfectly flat, not easy on super thin material, any lifting causes the cutter to got a little to deep and the lines get thick fast.
Must use lube! i just gave this a blast with CRC it really helped.
Problems:
The carbide has chipped (red arrows) ( :( $50US per insert) and i don't know why, there are wear marks on the shaft (white) and i dont know why. i watched the entire job and the shaft and cutter never cam in contact with anything, its got me puzzled.
« Reply #134 on: December 14, 2010, 05:22:10 PM »
Double sided tape works well to keep it flat.
Phil
« Reply #135 on: December 15, 2010, 04:35:15 AM »
I have one of the nine9 engraving cutters, mine is the 45 degree one, yours looks like the 60.
I havent had any problems with it chipping up the side like yours so not sure whats happening there, presume you are spinning it fast enough for the feed?
« Reply #136 on: December 15, 2010, 01:28:40 PM »
4000RPM is max for my machine, according to the documentation 0.02-0.08 (mm/rev) is does suggest a S speed of between 5000-20000 RPM, what do you run yours at?
« Reply #137 on: December 15, 2010, 01:40:17 PM »
My max spindle is 3800 and I think 200mm/min is what I usually run at, so just a bit over 0.05mm/rev
« Reply #138 on: December 16, 2010, 01:09:08 AM »
Got the draw fronts folded up today, isnt this project really starting to come along?
Why is the middle one missing, was just to tight, need to spend a bit more time making it fit.
« Reply #139 on: December 16, 2010, 02:16:59 AM »
Coming along nicely! Time to get it painted...
