Hello Guest it is June 12, 2026, 12:08:03 AM
Author Topic: New PlugIn just about done..  (Read 337549 times)
0 Members and 12 Guests are viewing this topic.
cncguytoronto
Re: New PlugIn just about done..
« Reply #40 on: July 20, 2007, 08:27:14 AM »
Hello, does anyone know why when I install the shuttle pro plugin on a fresh machine with mach 3 I only get all the buttons working but not the two inner wheels....oohhh yes when I assign the Select X, Select Y, Select Z to buttons they also dont work....I keep getting an error in the Status: Unkown word where unary operation could be.....
Other than that it works great....
CNC Guy Toronto
Shane
Reply
cncguytoronto
« Reply #41 on: July 20, 2007, 02:05:13 PM »
Hey Art....I am posting some problems I am having with my shuttle pro with version 1.90...buttons are working but when I assign the select X, or Y or Z axis to a button they do not...also the center wheels dont work...is it my version that is causing the problem ?
Can you confirm....
I keep getting an error in the status...
cncguytoronto
shane
« Reply #42 on: October 26, 2007, 05:59:56 PM »
I have a ShuttleXpress and have it working in Mach3 but it will only work in Inc. When I toggle it to continuous it won't do anything.  The outer wheel doesn't seem to do anything.  I thought I saw a post about the outer ring doing continuous and the inner doing Inc.  That would be very cool.  I didn't see this in the pulldown menu, but is there a way to make a button toggle between the different Inc. modes, .100-- .010 --.001?
« Reply #43 on: November 13, 2007, 01:33:43 PM »
I seem to have the same problem with my shuttlepro, since the 2.58 update.
The inner and outer ring don't work correctly.
When I turn the inner ring it will start jogging very slowly the selected axis in the positive direction, doesn't matter wich direction I turn the ring, it will always go positive. It will only stop when pressing ESC. The outer ring doesn't work on anything anymore...
Never had this problem before the update.
Offline Greolt
  •  956 956
« Reply #44 on: November 13, 2007, 03:43:40 PM »
I believe you must also have the latest plugin.
Download the plugin again and install this should fix it.
Greg
« Reply #45 on: November 13, 2007, 05:00:11 PM »
Hello,
first: I'm german, so please excuse my bad english...
I think about buying such a ahuttle-pro-2-device, but since i read the last few posts, I'm afraid it won't work correctly...?
Can anyone resolve my doubts?
Or maybe anyone can do a little summary how exactly it works with Mach3 and what it does and what it can't do...?
Marc
Plz excuse my english, I'm german :-D
« Reply #46 on: November 14, 2007, 01:53:36 AM »
Hi Greg,
I downloaded the latest plugin from the website 13th november with the 2.58 version..no luck..innner wheels don't work.
I downgraded it to 2.00.014 and everything works o.k.
So I think the plugin isn't compatable with the 2.58 version?
In the new version you can set the pullley ratio under config-pulley, so I can influence the spindle rpm displayed in the screen. Does anyone know how to change this in the old versions?
Hope they fix the plugin!
to Marc: Marc, I have no doubts about buyin the shuttle pro, I would do it again! (Also kaufen dass Gerat!)
regards,
Aryan
« Reply #47 on: November 14, 2007, 04:38:46 AM »
Hi there
german agents here...?  :D Nice  :)
OK, so I'll send my wishlist to Santa immediately :D
Thank you very much for this fast reply
« Reply #48 on: November 14, 2007, 01:45:36 PM »
guys...
I finally found the problem after mailing with Art
I downloaded the new plugin and copied it to the Mach directory...however I forgot to double click on it! :-[
my Shuttle-Pro works like it shoud again! ;D
« Last Edit: November 16, 2007, 11:11:04 AM by adryan »
« Reply #49 on: November 20, 2007, 03:54:46 AM »
lol ;)
But thanks anyway. I have just ordered mine ;)
