Hello Guest it is October 05, 2026, 01:56:32 AM
Author Topic: Licening problem  (Read 34936 times)
simolke
Licening problem
« on: June 18, 2006, 02:13:20 PM »
I have a tag mill it workers fine with Mach 2 the motors wont work with Mach 3/4 an I bought license . I received secend copy of license an will still not work . Wizard said unlicensed file. can some one help :'(
Re: Licening problem
« Reply #1 on: June 18, 2006, 04:11:47 PM »
Look in mach3 Directory, is there a Mach1Lic.dat file? If there is not copy it from the Mach2 directory and place a copy of it in the Mach3 directory.
www.newfangledsolutions.com
www.machsupport.com
simolke
« Reply #2 on: June 18, 2006, 04:31:58 PM »
There a Machlic in the file  I have rerun file several times
« Reply #3 on: June 18, 2006, 05:30:55 PM »
under help / about do you see your name?
Also you should be able to move your motors is you don't have a licanse... Could you please post your Mach2 and Mach3 XML files? I would like to check them to see if you have a bad setting.
Brian
www.machsupport.com
simolke
« Reply #4 on: June 18, 2006, 06:01:37 PM »
how do i post the file to you
simolke
« Reply #5 on: June 18, 2006, 06:02:48 PM »
how do i post the files to you so you can inspect to see if it's corrupted
simolke
« Reply #6 on: June 18, 2006, 06:06:01 PM »
Try this
simolke
« Reply #7 on: June 18, 2006, 06:14:31 PM »
hear is Mach2
« Reply #8 on: June 18, 2006, 07:03:24 PM »
The Mach2 one is an XML not a sys file :) i think you got the wrong one..
www.machsupport.com
simolke
« Reply #9 on: June 18, 2006, 10:51:15 PM »
Is whathyou want
