Hello
Guest
it is
October 14, 2026, 03:03:34 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Licening problem
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Licening problem (Read 35007 times)
simolke
Licening problem
on:
June 18, 2006, 02:13:20 PM »
I have a tag mill it workers fine with Mach 2 the motors wont work with Mach 3/4 an I bought license . I received secend copy of license an will still not work . Wizard said unlicensed file. can some one help
Logged
Brian Barker
3,860
Re: Licening problem
Reply #1 on:
June 18, 2006, 04:11:47 PM »
Look in mach3 Directory, is there a Mach1Lic.dat file? If there is not copy it from the Mach2 directory and place a copy of it in the Mach3 directory.
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
simolke
Reply #2 on:
June 18, 2006, 04:31:58 PM »
There a Machlic in the file I have rerun file several times
Logged
Brian Barker
3,860
Reply #3 on:
June 18, 2006, 05:30:55 PM »
under help / about do you see your name?
Also you should be able to move your motors is you don't have a licanse... Could you please post your Mach2 and Mach3 XML files? I would like to check them to see if you have a bad setting.
Brian
Logged
www.machsupport.com
simolke
Reply #4 on:
June 18, 2006, 06:01:37 PM »
how do i post the file to you
Logged
simolke
Reply #5 on:
June 18, 2006, 06:02:48 PM »
how do i post the files to you so you can inspect to see if it's corrupted
Logged
simolke
Reply #6 on:
June 18, 2006, 06:06:01 PM »
Try this
Logged
simolke
Reply #7 on:
June 18, 2006, 06:14:31 PM »
hear is Mach2
Logged
Brian Barker
3,860
Reply #8 on:
June 18, 2006, 07:03:24 PM »
The Mach2 one is an XML not a sys file
i think you got the wrong one..
Logged
www.machsupport.com
simolke
Reply #9 on:
June 18, 2006, 10:51:15 PM »
Is whathyou want
Logged
Print
Pages:
1
2
Go Up
« previous
next »
