Hello Guest it is October 13, 2026, 02:11:31 AM
Author Topic: Licening problem  (Read 34997 times)
Re: Licening problem
« Reply #10 on: June 19, 2006, 08:08:57 AM »
You need to set up your ports and pins :( If you look you have all the Step and Direction pins set to 2 & 3... once you set them to what you have in Mach2 you should be up and running :)
www.newfangledsolutions.com
www.machsupport.com
simolke
« Reply #11 on: June 19, 2006, 05:18:15 PM »
will this fix the wizard problem to . wizard said that I was unlicensed .
simolke
« Reply #12 on: June 19, 2006, 08:53:11 PM »
Motors running now . Last time I rubout Mach3 must have loss setup . Only problem now is Wizard stated unlicensed .
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
« Reply #13 on: June 19, 2006, 09:04:43 PM »
Hi:
 Thats because the Conversational Wizardsa are a separate license available only from www.newfangledsolutions.com
Art
simolke
« Reply #14 on: June 20, 2006, 09:50:59 PM »
I wouldlike to thank youfor helping me through my  problems  an I will be gitting the wizard but don't like using paypal . Is there a nother way. ;D
« Reply #15 on: June 20, 2006, 09:56:09 PM »
If you would like I can send you my address off line and  you could send a check..
Hope that works for you
Brian
www.machsupport.com
