Hello Guest it is November 01, 2026, 10:06:05 AM
Author Topic: lazycam  (Read 108274 times)
Re: lazycam
« Reply #10 on: June 26, 2006, 06:30:33 PM »
The file runs here... Could you check to see that you are not in inverse time mode (G93) ? You should be in G94 UPM mode
www.newfangledsolutions.com
www.machsupport.com
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: lazycam
« Reply #11 on: June 26, 2006, 10:34:03 PM »
Hi, Brian
The code changes you made work great.
Thank's Chip
Re: lazycam
« Reply #12 on: June 26, 2006, 10:53:11 PM »
It is about time :) I have been adding code for an OEM so there were many changes in LCAM.... I was working all the bugs out and now it is time to start back on the offset path  :o That is not as much fun as I had hoped it would be  ;) I have all the line to line code done! so LCAM can take a path that is all lines and offset the path and trim all the lines to the right length... This is all so the first part to get pocketing done... I need more TIME!!!!
Thank you (Just wanted to tell you what I was working on next)
www.machsupport.com
Re: lazycam
« Reply #13 on: June 27, 2006, 08:21:02 AM »
where we change g93 to g94 in settup
thank you
Re: lazycam
« Reply #14 on: June 28, 2006, 03:31:03 PM »
ok now it working i put in pre-amble to code output
G94 an it change the mode on mach3 this is ok
one more think
if i load dxf file and keep layer info. it work ok but i have to enter all the info for layer control
like feed plunger hight  ext. take time to enter
if i load dxf and ignore layer inf. the layer control all the info are there if i put outside off
in the inside if i have dot it show the dot and if i generate the gcode all the dot it say Radius to end of arc differ from radius to start on line number #17
N1 (File cut22 )
N2 (File Posted in Mill Mode)
N3 (Wednesday, June 28, 2006)
N4 G90G80G40G94 G90.1
N5 G0 Z10.0000
N6    X37.0742 Y19.0897
N7 M3
N8    Z9.5000
N9 G1 Z0.0000  F300.00
N10 G0G98 Z10.0000
N11 G81 X37.0742 Y19.0897 Z0.0000 R10.0000 F500.00
N12 G0 X197.8373 Y25.6922
N13    Z9.5000
N14 G1 Z0.0000  F300.00
N15 G80
N16    X189.7125  F500.00
N17    Y74.2922
N18 G3 X170.6625 Y93.3422 I170.6625 J74.2922
N19 G1 X67.4625
N20 G3 X48.4125 Y74.2922 I67.4625 J74.2922
N21 G1 Y25.6922
N22    X40.2878
N23 G0 Z10.0000
N24    X203.8787 Y21.1578
N25    Z9.5000
N26 G1 Z0.0000  F300.00
N27 G98 Z10.0000
N28 G81 X203.8787 Y21.1578 Z0.0000 R10.0000 F500.00
N29 G0 X221.0625 Y0.0000
N30    Z9.5000
N31 G1 Z0.0000  F300.00
N32 G80
N33    Y13.6922  F500.00
N34    X238.1250
N35    Y110.1672
N36 G3 X211.1375 Y137.1547 I211.1375 J110.1672
N37 G1 X26.9875 Y137.1547
N38 G3 X0.0000 Y110.1672 I26.9875 J110.1672
N39 G1 Y13.6922
N40    X17.0625 Y13.6922
N41    X17.0625 Y0.0000
N42 G0 Z10.0000
N43 M5 M9
N44 X0.0 Y0.0
N45 G40G80M30
thank you
Re: lazycam
« Reply #15 on: June 28, 2006, 06:21:22 PM »
There is an error that I can't seem to get to happen here.. I can see the problem in the Gcode file I just don't know how you are getting it to do it :(
I will look at it again
Thank you
Brian
www.machsupport.com
Re: lazycam
« Reply #16 on: June 28, 2006, 06:34:27 PM »
I found it and it is now fixed :)
www.machsupport.com
Re: lazycam
« Reply #17 on: June 28, 2006, 07:02:25 PM »
if it fix send to me
thank you
Re: lazycam
« Reply #18 on: June 28, 2006, 07:35:20 PM »
well done
good work
one think funny
check line n8 z go down
n9 go up
n10 go down again
it make the hole 2 times
same think 21 22 23
1 (File cut22 )
N4 G90G40G80G94 G91.1
N5 G0 Z10.0000
N7 M3
N8 G1 Z0.0000  F300.00
N9 G0 G98 Z10.0000
N10 G81 X37.0742 Y19.0897 Z0.0000 R10.0000 F500.00
N11 G80
N12 G0 X189.7125 Y25.6922
N13 G1 Z0.0000  F300.00
N14    Y74.2922  F500.00
N15 G3 X170.6625 Y93.3422 I-19.0500 J0.0000
N16 G1 X67.4625
N17 G3 X48.4125 Y74.2922 I-0.0000 J-19.0500
N18 G1 Y25.6922
N19 G0 Z10.0000
N20    X203.8787 Y21.1578
N21 G1 Z0.0000  F300.00
N22  G98 Z10.0000
N23 G81 X203.8787 Y21.1578 Z0.0000 R10.0000 F500.00
N24 G80
N25 G0 Z10.0000
N26 M5 M9
N27 X0.0 Y0.0
N28 G40M30G80
Re: lazycam
« Reply #19 on: July 01, 2006, 09:43:42 AM »
Hi Brian
did you find solution for the dot  the reason it making 2 time the hole
thank you
