Hello Guest it is November 01, 2026, 10:06:19 AM
Author Topic: lazycam  (Read 108278 times)
Re: lazycam
« Reply #20 on: July 01, 2006, 08:29:18 PM »
I will have a look at it... Didn't know it was doing that!
Thanks Brian
www.newfangledsolutions.com
www.machsupport.com
Re: lazycam
« Reply #21 on: July 05, 2006, 08:59:52 PM »
any new developement on lazycam last problem
thank
Re: lazycam
« Reply #22 on: July 05, 2006, 09:24:26 PM »
It is fixed for the next rev... :)
www.machsupport.com
Re: lazycam
« Reply #23 on: July 06, 2006, 05:59:55 AM »
if it fix send to me
thank you
Re: lazycam
« Reply #24 on: July 06, 2006, 07:34:01 AM »
There will be a release out today :) I just sent it to Art...
Brian
www.machsupport.com
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: lazycam
« Reply #25 on: July 06, 2006, 02:00:25 PM »
Hi, Brian
Would / could you please comment on the changes you've made from one rev. to another.
I now are busy, maybe (LasyCam Revision Note's) just short comment's.
Thank's Chip
Re: lazycam
« Reply #26 on: July 06, 2006, 02:44:04 PM »
The Gcode output is fixed so it will not drill the first hole two times in the first drill cycle.
The other thing that I added is rotoation :) you can rotate the part X amount of degrees and it will re calculate the stock size that you need to get the part :)
www.machsupport.com
Re: lazycam
« Reply #27 on: July 06, 2006, 09:40:47 PM »
problem 2.56
check
at the beagening line n5 it shoul put z to 10 and afetr move x an y break the tool on z
line 16 same think after finish cutting the part z sould be up beafore x an y move
on ver 2.55 it was ok only the 2 time hole was the problem
1 (File cut232 )
N2 (File Posted in Mill Mode)
N3 (Thursday, July 06, 2006)
N4 G90G40G80 G91.1
N5 G0 X37.0742 Y5.3976 Z10.0000
N6 G0 G98 Z10.0000
N7 G81 X37.0742 Y5.3976 Z0.0000 R10.0000 F3000.00
N8 G80
N9 G0 X189.7125 Y12.0000
N10 G1 Z0.0000  F1000.00
N11    Y60.6000  F3000.00
N12 G3 X170.6625 Y79.6500 I-19.0500 J0.0000
N13 G1 X67.4625
N14 G3 X48.4125 Y60.6000 I-0.0000 J-19.0500
N15 G1 Y12.0000
N16 G0 X203.8787 Y7.4656 Z10.0000
N17  G98 Z10.0000
N18 G81 X203.8787 Y7.4656 Z0.0000 R10.0000 F3000.00
N19 G80
N20 G0 Z10.0000
N21 M5 M9
N22 X0.0 Y0.0
N23 G40M30G80
tahak you
Re: lazycam
« Reply #28 on: July 07, 2006, 07:55:00 AM »
Looking into it :)
www.machsupport.com
Re: lazycam
« Reply #29 on: July 08, 2006, 09:39:22 PM »
find any solution
jacques
