Hello Guest it is November 01, 2026, 10:06:12 AM
Author Topic: lazycam  (Read 108276 times)
Re: lazycam
« Reply #30 on: July 08, 2006, 10:02:28 PM »
It is fixed and will be out with the next Mach3 release... I could put it on the ftp server if you like
www.newfangledsolutions.com
www.machsupport.com
Re: lazycam
« Reply #31 on: July 08, 2006, 10:28:56 PM »
It is on the FTP server  ;D
www.machsupport.com
Re: lazycam
« Reply #32 on: July 09, 2006, 07:00:39 AM »
it look better
one more think
line n8
line n20
the speed z go trow it sould be f1000 like line 11
on line n8 n20 the r12.0000 where this is come from it look like from rapid hight
1 (File cut232 )
N2 (File Posted in Mill Mode)
N3 (Sunday, July 09, 2006)
N4 G90G40G80 G91.1
N5 G0 Z12.0000
N6    X37.0742 Y5.3976
N7 G0 G98 Z12.0000
N8 G81 X37.0742 Y5.3976 Z0.0000 R12.0000 F3000.00
N9 G80
N10 G0 X189.7125 Y12.0000
N11 G1 Z0.0000  F1000.00
N12    Y60.6000  F3000.00
N13 G3 X170.6625 Y79.6500 I-19.0500 J0.0000
N14 G1 X67.4625
N15 G3 X48.4125 Y60.6000 I-0.0000 J-19.0500
N16 G1 Y12.0000
N17 G0 Z12.0000
N18    X203.8787 Y7.4656
N19  G98 Z12.0000
N20 G81 X203.8787 Y7.4656 Z0.0000 R12.0000 F3000.00
N21 G80
N22 G0 Z12.0000
N23 M5 M9
N24 X0.0 Y0.0
N25 G40M30G80
Re: lazycam
« Reply #33 on: July 09, 2006, 08:14:15 AM »
let me know when you put on ftp server it important the i made was on last download from ftp
thank you
Re: lazycam
« Reply #34 on: July 09, 2006, 08:16:35 AM »
the last nc file  was made  on last download from ftp
thank you
Re: lazycam
« Reply #35 on: July 09, 2006, 08:31:55 AM »
I don't see a problem with the Gcode file... If you would like the feedrate changed, you can do that by clicking on the chain and changing it on right hand side. The R is at the rapid hight .. Did you want it at some other height?
Brian
www.machsupport.com
Re: lazycam
« Reply #36 on: July 09, 2006, 08:54:58 AM »
i anderstand your point but i think when the z axe go down it should be  going down at the plunge rate set up to reach  z0.00
it could be change on chain but we have to enter every time an if we forget z go down to fast
thank you
jacques
Re: lazycam
« Reply #37 on: July 09, 2006, 10:02:02 AM »
All Z- moves are done at a feedrate. I still can't see the trouble even after test running it  (it was a late night).
Brian
www.machsupport.com
Re: lazycam
« Reply #38 on: July 09, 2006, 09:15:07 PM »
the last lazycam is ok
could you put option for milling machine when we use drill g81 z will be plunge rate speed
jacques
Re: lazycam
« Reply #39 on: July 10, 2006, 05:55:07 AM »
okay, I will it for the next release
www.machsupport.com
