Hello Guest it is November 01, 2026, 10:06:01 AM
Author Topic: lazycam  (Read 108273 times)
lazycam
« on: June 17, 2006, 08:57:44 AM »
Question
with ver 1 no problem
with vewr 2.53
i am using milling and wiht setup in lazycam
when the milling bit go down it ok but when it go up the z move in same time with x an y this is a problem and do the have a way to set up all the layer control an keep for next dxt
Re: lazycam
« Reply #1 on: June 17, 2006, 09:07:03 AM »
There is a new rev coming out later this weekend :)
www.newfangledsolutions.com
www.machsupport.com
Re: lazycam
« Reply #2 on: June 22, 2006, 09:30:42 AM »
hi Brian
in any diffren using lazy cam with mach 3  ver 1.90.041 and ver 1.90.051
thank you
Re: lazycam
« Reply #3 on: June 22, 2006, 12:58:30 PM »
It should be all fixed :)
www.machsupport.com
Re: lazycam
« Reply #4 on: June 23, 2006, 10:22:11 PM »
i try mach3 ver 1.90.052 with lazycam ver 2.53
it look ok but one think is buy me is every time i use lazycam we have to enter feed rate plunge rate spindle
rapid hight for each layer and so it mush have one way to keep the info for outside
inside 1 inside 2 inside 3 and so
thank you
jacques lambert
Re: lazycam
« Reply #5 on: June 24, 2006, 06:56:20 AM »
It should keep the data that you entered the last time you used the layer.. I will look to see if it is not updating
www.machsupport.com
Re: lazycam
« Reply #6 on: June 24, 2006, 03:59:59 PM »
you should have place to download lazycam i saw there is ver 2.54 i download last ver mach and it not inside so we could do some test
Re: lazycam
« Reply #7 on: June 25, 2006, 01:58:32 PM »
hi test on
lazycam 2.54 need info
G4 p0.0000 where we do setup for time
z plunge rare missing
and give  error f word missing
(File j2 )
(File Posted in Mill Mode)
(Sunday, June 25, 2006)
G90G80G40 G90.1
G0 Z10.0000
   X17.0625 Y0.0000
M3 S0
   Z0.0000
G4 P0.0000
G1 X0.0000  F5000.00
   Y96.4750
G2 X26.9875 Y123.4625 I26.9875 J96.4750
G1 X211.1375
G2 X238.1250 Y96.4750 I211.1375 J96.4750
G1 Y0.0000
   X221.0625
G0 Z10.0000
   X54.7625 Y12.0000
   Z0.0000
G4 P0.0000
G1 Y60.6000
G2 X73.8125 Y79.6500 I73.8125 J60.6000
G1 X164.3125
G2 X183.3625 Y60.6000 I164.3125 J60.6000
G1 Y12.0000
G0 Z10.0000
M5 M9
X0.0 Y0.0
G40G80M30
thank you
Re: lazycam
« Reply #8 on: June 25, 2006, 02:33:17 PM »
sorry about that it is fix and will be out latter today if I can get Art to upload it again.
Thank you
Brian
www.machsupport.com
Re: lazycam
« Reply #9 on: June 26, 2006, 05:26:19 PM »
mach 3 ver 1.090.053
lazycam ver 2.54
mach3 error
f word with inverse time arc move on line number #11
no rate plunger on z
is it some think on my side or
N1 (File j2 )
N2 (File Posted in Mill Mode)
N3 (Monday, June 26, 2006)
N4 G90G80G40 G90.1
N5 M6 T2
N6 G43 H2
N7 G0 Z10.0000
N8    X54.7625 Y12.0000
N9 M3 S1000
N10    Z0.0000
N11 G1 Y60.6000  F5000.00
N12 G2 X73.8125 Y79.6500 I73.8125 J60.6000
N13 G1 X164.3125
N14 G2 X183.3625 Y60.6000 I164.3125 J60.6000
N15 G1 Y12.0000
N16 M6 T1
N17 G43 H1
N18 G0 Z10.0000
N19    X17.0625 Y0.0000
N20    Z0.0000
N21 G1 X0.0000
N22    Y96.4750
N23 G2 X26.9875 Y123.4625 I26.9875 J96.4750
N24 G1 X211.1375
N25 G2 X238.1250 Y96.4750 I211.1375 J96.4750
N26 G1 Y0.0000
N27    X221.0625
N28 G0 Z10.0000
N29 M5 M9
N30 X0.0 Y0.0
N31 G40G80M30
