Hello Guest it is October 21, 2026, 07:24:40 AM
Author Topic: mill retro HELP  (Read 368388 times)
Re: mill retro HELP
« Reply #140 on: August 13, 2008, 07:32:06 PM »
 ;D
Re: mill retro HELP
« Reply #141 on: August 13, 2008, 09:02:21 PM »
Dancing Mario ? ? ?
I thought it was the Police "Dash Cam" of Brett's last DUI !
RC
Re: mill retro HELP
« Reply #142 on: August 13, 2008, 09:30:48 PM »
 ;D :o ;D :-*
Re: mill retro HELP
« Reply #143 on: August 13, 2008, 11:37:37 PM »
 :D  LOL, now what ever
made me think it was one of you two ?  :D
QUESTION
btw, what type of relay do you use to start your spindle ? solid state to trip a bigger relay?
I have 24v relays to start spindle, but will need less volt relay for mach to trigger them.
thanks guys ,and good to find good people with a sense of humor.
LOL :D
Ed
Ed VanEss
Re: mill retro HELP
« Reply #144 on: August 14, 2008, 01:50:19 AM »
Ed, when did the wife start smoking? ;D
 My spindle on the lathe is controlled by a contactor with a 24v coil and I use a PLC to operate that via ModBus. You could use any kind of relay that operates from 5v, solid state are more expensive but I suppose they may last longer.
Re: mill retro HELP
« Reply #145 on: August 14, 2008, 02:57:49 AM »
OH, SO YOU RECOGNIZED HER?  :D
You didn't know I married Bretts sister. :D
Can't  I just use pin 17 through my PMDX To a 5v relay?
Why when I go to a wizard page , I can not exit. I have to close mach and restart ?
Ed
Ed VanEss
Re: mill retro HELP
« Reply #146 on: August 14, 2008, 03:08:31 AM »
Well I kind of thought that, certainly a strong family resemblace ;)
The PMDX 122 (That what you have? ) has a relay on it, you could use that to switch another relay or I suppose even switch the spindle itself if the  current and voltage are within specs of the relay. Personally I wouldnt switch directly as it would mean your AC would be right at the PMDX and it introduces possibilities of noise. If you dont have a contactor then using a larger relay switched by the PMDX one would be a decent solution, think I would go higher on the coil voltage than 5V as again noise is less of an issue but that will depend on your machine and whether you already have 24V. My lathe and the mill I am doing at the moment have 24V on all of the control side of things such as limits.
 Wizards should go back to the main Mach page when you press the Exit (return to mach in some) Sometimes they can take aa while to go back depending on the macro they use and how much its calculating however it shouldnt be any more than a few seconds. Which wizards are you havng problems with and which version of Mach are you using.
Re: mill retro HELP
« Reply #147 on: August 14, 2008, 03:25:39 AM »
Hood,
using v 2.63. tried a couple different wizards. rec pocket cir pocket. won't exit.   I have v 3. on machine and that one works.
My motor starter relays are 110v which I was going to trigger with the 24 v relay which would be triggered by a lower volt relay.
I suppose I could tigger the 24 v relay through the pmdx relay, but what if I want reverse?  ??? ???
Going to bed now with Bretts sister. Gotta get some more bags. she keeps burning holes through them.  ;D
Ed
Ed VanEss
Re: mill retro HELP
« Reply #148 on: August 14, 2008, 05:40:59 AM »
 ;D
Ed, Have a look at opto 22s site. You can get an opto relay that will switch 30 amps operated by 5V for about $30.00 I think and it is opto isolated.
Re: mill retro HELP
« Reply #149 on: August 18, 2008, 11:25:31 PM »
Finally got my z axis working right. When in MDI- g0z1.000 , would only move .125. :-[
 did more motor tuning backed off on accel, and changed steps to 4000.
 working good now. :D  homing and limits coming up now.Have to make some trippers to mount on table.
Bretts sister says  UGHHHHHHH- UGHHHHHHHH  ;D
Ed
Ed VanEss
