Hello Guest it is October 20, 2026, 11:11:46 PM
Author Topic: mill retro HELP  (Read 368168 times)
Re: mill retro HELP
« Reply #50 on: July 31, 2008, 09:29:09 PM »
Hood,
OK, thats what i thought, but was'nt sure. the instuctions show "under multipler board" but there's nothing there.
Ed V
Ed VanEss
Re: mill retro HELP
« Reply #51 on: August 01, 2008, 01:58:48 AM »
You probably have an earlier revision, the manuals say for Rev 7. Maybe Gecko can supply an older manual for you if that is the case.
Re: mill retro HELP
« Reply #52 on: August 01, 2008, 05:26:50 PM »
Hood,  Chip,
 I found this pdf. This ones like mine. ;)
Thanks to you both, I'LL  now carry on.
Ed V,
Ed VanEss
Re: mill retro HELP
« Reply #53 on: August 01, 2008, 05:30:00 PM »
Keep us updated :)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: mill retro HELP
« Reply #54 on: August 01, 2008, 05:37:55 PM »
Hi, ED
Yes, Updates.
Chip
Re: mill retro HELP
« Reply #55 on: August 01, 2008, 08:15:22 PM »
Hood, Chip
Will do - right till the end.
 I just did the test points on the X and got my volt readings just like the instruction say.
Sometimes you just have to walk away and take a break [for a few days]  :D
My last machine took over a year to complete.  Monday I have a job coming in. A 38 ford pickup street rod.
Wants a tilt front end. Thats the kind of stuff I do.
Later Guys.
Thanks again
I will be back.
Ed V
Ed VanEss
Offline comet
  •  338 338
Re: mill retro HELP
« Reply #56 on: August 02, 2008, 03:15:21 AM »
   reading back about the estop,I would put it on the DC side of the PSU because if you have decent size capacitors the motors
will run on after you estop-just a thought.
Re: mill retro HELP
« Reply #57 on: August 02, 2008, 01:34:14 PM »
Hi Comet,
Exactly, my thoughts, but according to Gecko instructions, not to switch dc power to drives.
Don't know why, but thats where e-stop is on my other machine.
Thanks for your input, I need all I can get.
Ed V.
Ed VanEss
Re: mill retro HELP
« Reply #58 on: August 02, 2008, 11:30:36 PM »
  This is off Gecko instructions
    "STEP 2: POWER SUPPLY HOOK-UP
    CAUTION! Never put a switch on the DC side of the power supply! This will damage, if not destroy, your drive!"
  So, whats the best way to e-stop ? I want my e-stop to kill all servo and spindle power.
  Ed V
Ed VanEss
Offline Chip
  •  2,055 2,055
Re: mill retro HELP
« Reply #59 on: August 03, 2008, 01:47:59 AM »
Hi, Ed
In your E-Stop setup, You can add a latching relay,(4 pol double throw relay) to Re-set the Gecko's and on E-Stop it Gnd's the Err/Rst pin's.
With your E-Stop in "Normal State", This Relay is wired to On/Closed, The Common Term's, One to each Gecko Err/Rst pin, NC's to Gnd and NO's to Blocking Diodes to a NO Push Button with 5 volt's on the other terminal, (Push & hold till the Drives Reset).
This allows all drives to be re-set only when in non E-Stop mode.
The 4th pol of the relay can be wired to Mach to E-stop Mach's Reset Button if the Maine E-Stop is Pushed
If you wire in an additional Relay (small 5 volt) contact's wired into this 4 pol Relays Coil, Mach can control the Drives re-set also.
With some Zener Diode's, Should be able to Halt Mach with a single drive faults also.
I've got a diag. around hear somewhere, Looking for It.
Hope this makes some sense, Chip
