Hello Guest it is November 13, 2026, 05:17:06 PM
Author Topic: OEM codes for buttons, DRO's and LED's  (Read 1085177 times)
Re: OEM codes for buttons, DRO's and LED's
« Reply #70 on: December 30, 2016, 02:33:47 PM »
What is the magic OEM button code for "auto tool zero"
« Reply #71 on: December 30, 2016, 05:24:32 PM »
There isn't one.
OEM codes are for built in functions.
There is no built in auto zero function.
Auto zero routines are user written macro's.
Offline Klaus
  •  42 42
« Reply #72 on: October 16, 2018, 03:31:33 AM »
Hi
Sorry I new to all this, but how is all this with the OEM code working? Is there a description somewhere or can somebody please explain?
Klaus
« Reply #73 on: October 16, 2018, 06:23:10 AM »
« Reply #74 on: December 11, 2018, 11:11:22 PM »
dear master..need your help for Mach3Mill
if  (Changetools LED process)OEMLED806 "ON"...i need Signal output6 "ON"
decari
Offline TPS
  •  2,627 2,627
« Reply #75 on: December 12, 2018, 12:22:44 AM »
output6 -> OEMLed(79)
« Reply #76 on: December 12, 2018, 12:48:30 AM »
External Button-OEM codes ->Triger # OEM code 1=1000(cycleStart)
input signal -> OEM Trig#1=Pin no.0
If Pin no.0 "ON"= cycleStart "ON"
Dear TPS...
is it same methode
decari
Offline TPS
  •  2,627 2,627
« Reply #77 on: December 12, 2018, 01:00:24 AM »
for the Moment i am not able to catch the Problem.
« Reply #78 on: December 12, 2018, 01:11:14 AM »
 Pls help ....signal output for OEM806(LED ChangeTools)?
« Reply #79 on: December 12, 2018, 01:17:01 AM »
i only need "signal output triger" for OEM806(LED ChangeTools)
How to make ...Change tools have output triger signal ?
decari
