Hello Guest it is November 13, 2026, 05:06:02 PM
Author Topic: OEM codes for buttons, DRO's and LED's  (Read 1085145 times)
Re: OEM codes for buttons, DRO's and LED's
« Reply #90 on: October 04, 2019, 05:46:15 AM »
hello Chaps-
Found this thread while looking for a way of "set home X" and "set home Z"
how do i write this into gcode?
thanks for the help
regards fred
« Reply #91 on: December 26, 2019, 01:32:01 PM »
Hi!
I want to ask you if there is a way that the numbed is working in Mach3 also. I have it from Estlcam and would like to use the same keys also in Mach3.
Single Axis Movement went fine by set it at the hotkey menu. But 2 axis by press 1,3,7 or 9 and the other functions will work only with macro, sure? (see pic)
Does anyone give me a little help for programming, I am new in mach3 scripting...
Greets Markus
« Reply #92 on: November 16, 2020, 11:13:14 AM »
good afternoon .  I'm new here, and I'm in need of help.  I need to do a function on the machine, that when pressing the button it activates an output for 1 second, and when I press it again it activates another output for 1 second, I will use to fix the part, activate two valves, one to close and one to open  .  How can I do it ?  I'm using input 6, and outputs 3 and 4.
Used mach3 and board nven v2
Tanks
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #93 on: November 16, 2020, 05:52:58 PM »
Sorry we do not support Novusun products due to licence violations.
