Hello Guest it is November 13, 2026, 05:05:54 PM
Author Topic: OEM codes for buttons, DRO's and LED's  (Read 1085142 times)
Offline TPS
  •  2,627 2,627
Re: OEM codes for buttons, DRO's and LED's
« Reply #80 on: December 12, 2018, 01:53:16 AM »
still not sure, but maybe you are looking for something like this
IF GetOEMLed(806) then
  ActivateSignal(OUTPUT6)
Else
  DeactivateSignal(OUTPUT6)
End If
« Reply #81 on: December 12, 2018, 04:56:10 PM »
Thanks very much..i Will try it... thanks
« Reply #82 on: December 12, 2018, 05:00:26 PM »
This signal...i want to make external unit (change tools) by plc.
Combine plc and board...thanks
« Reply #83 on: February 28, 2019, 10:53:12 AM »
Hey guys.
Does anyone know why my MACH3 brain does not have some of the DROs?
I looked into the list posted by Hood and another one by Brett and a few other lists that I could find online. All of them includes these:
For example:
75 - Stock Size DRO
836 - Current Tool length DRO
I know there was a couple more that are missing, but I can't remember them.
I use MACH3 R3.043.066
Did later versions of MACH removed some of the DRO's ?
Offline TPS
  •  2,627 2,627
« Reply #84 on: February 28, 2019, 11:50:14 AM »
just type in the number, not all of them are in the pull down list.
« Reply #85 on: February 28, 2019, 01:40:46 PM »
Thank you for the reply,
I tried, with no success. "old codes" and "new codes". Tried to set it in the pull-down field and "Use DRO Number" field. Still can't pull out Tool length DRO...
Offline TPS
  •  2,627 2,627
« Reply #86 on: March 01, 2019, 12:42:21 AM »
see attachment
« Reply #87 on: March 01, 2019, 05:50:18 AM »
Yes, that's how I did. I can create a rung 836, but the output is always 0.0000 while tool length is set as 7.250 (or any other value).
I tried as well "OEM 180 Machine Z coord - Z Work Offset - Tool length" with the same result.
In the end, I managed to get Tool Length by using OEM 42 (Tool Z Offset). It works like a charm!
And I got stock size by calculating values from other DROs.
I already used some other DROs that are not in pull/down list, and they work fine i.e 124, 126.
« Reply #88 on: September 03, 2019, 08:18:08 PM »
I was trying to find the codes for enslaving/freeing the B axis but the list is incomplete; doOemButton(367) will free the B axis but no code to enslave it.
Is there a definitive list of these codes? I've been trying to find a work-around for squaring the gantry of a router until I get a chance to add a second home switch for the B axis.
Offline TPS
  •  2,627 2,627
« Reply #89 on: September 07, 2019, 02:35:57 AM »
could also not find a buttoncode for entslaving. maybe
Button 254 DoOemButton Disable movement on axis B 254
can help?
