Hello
Guest
it is
November 01, 2026, 12:17:51 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
G-Code, CAD, and CAM
LazyCam (Beta)
LazyCam Pro question
« previous
next »
Print
Pages:
1
2
3
4
5
Go Down
Author
Topic: LazyCam Pro question (Read 74873 times)
Saumur
79
on:
February 06, 2008, 04:19:37 PM »
Hi guys.
With LazyCam i can import a drawing but then i don't know where i can set my tool's settings.
Can some1 explain me this?
Rybot
14
Re: LazyCam Pro question
Reply #1 on:
February 06, 2008, 07:05:03 PM »
After you import a DXF file click the Layers tab at the bottom of the Info window, press the tool button and input the name, diameter, feed rate and so on.
Saumur
79
Reply #2 on:
February 08, 2008, 09:02:41 AM »
Thanks.
Is there a way to put the measouring unit in mm? Because i work with mm but i can't find where i can change it.
Chip
2,055
Gainesville Florida USA
Reply #3 on:
February 08, 2008, 07:50:11 PM »
Hi, Saumur
LazyCam works in Units, If your DXF is in MM, Then it's MM in LCam.
Thanks, Chip
Saumur
79
Reply #4 on:
February 19, 2008, 09:07:06 AM »
can you work in diameter mode with lazycam?
thanks
Saumur
79
Reply #5 on:
February 21, 2008, 10:27:07 AM »
anyone?
Chip
2,055
Reply #6 on:
February 21, 2008, 01:47:03 PM »
Hi, Saumur
Lathe uses a Profile top half of your dxf drawing.
Hope this Helps, Chip
Saumur
79
Reply #7 on:
February 29, 2008, 10:20:44 AM »
Guys, i'm sending you the dxf i'm using.
If you can tell me how i have to configure lazycam to generate a g-code of this i would really appreciate it since i can't do it...
Saumur
79
Reply #8 on:
February 29, 2008, 11:03:17 AM »
I could do the g-code but i don't understand why when i put the tool it's like the program is not reading it.
In fact if i change the diameter of it the program will be the same.
Do i have to do something in Mach3 too?
Chip
2,055
Reply #9 on:
February 29, 2008, 05:59:14 PM »
Hi, Saumur
Is it a Lathe profile your looking for ?
Your dxf diden't clean up weii, Loaded it in BobCad, traced it and saved under dif name.
Is this what its should look like.
Thanks, Chip
Print
Pages:
1
2
3
4
5
Go Up
« previous
next »
