Hello Guest it is November 01, 2026, 01:00:39 PM
Author Topic: LazyCam Pro question  (Read 74885 times)
« on: February 06, 2008, 04:19:37 PM »
Hi guys.
With LazyCam i can import a drawing but then i don't know where i can set my tool's settings.
Can some1 explain me this?
Offline Rybot
  •  14 14
Re: LazyCam Pro question
« Reply #1 on: February 06, 2008, 07:05:03 PM »
After you import a  DXF file click the Layers  tab at the bottom of the Info window, press the tool button and input the name, diameter, feed rate and so on.
« Reply #2 on: February 08, 2008, 09:02:41 AM »
Thanks.
Is there a way to put the measouring unit in mm? Because i work with mm but i can't find where i can change it.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #3 on: February 08, 2008, 07:50:11 PM »
Hi, Saumur
LazyCam works in Units, If your DXF is in MM, Then it's MM in LCam.
Thanks, Chip
« Reply #4 on: February 19, 2008, 09:07:06 AM »
can you work in diameter mode with lazycam?
thanks
« Reply #5 on: February 21, 2008, 10:27:07 AM »
anyone?
Offline Chip
  •  2,055 2,055
« Reply #6 on: February 21, 2008, 01:47:03 PM »
Hi, Saumur
Lathe uses a Profile top half of your dxf drawing.
Hope this Helps, Chip
« Reply #7 on: February 29, 2008, 10:20:44 AM »
Guys, i'm sending you the dxf i'm using.
If you can tell me how i have to configure lazycam to generate a g-code of this i would really appreciate it since i can't do it...
« Reply #8 on: February 29, 2008, 11:03:17 AM »
I could do the g-code but i don't understand why when i put the tool it's like the program is not reading it.
In fact if i change the diameter of it the program will be the same.
Do i have to do something in Mach3 too?
Offline Chip
  •  2,055 2,055
« Reply #9 on: February 29, 2008, 05:59:14 PM »
Hi, Saumur
Is it a Lathe profile your looking for ?
Your dxf diden't clean up weii, Loaded it in BobCad, traced it and saved under dif name.
Is this what its should look like.
Thanks, Chip
