Hello
Guest
it is
November 01, 2026, 11:28:30 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
LazyCam (Beta)
LazyCam Pro question
« previous
next »
Print
Pages:
1
2
3
4
5
Go Down
Author
Topic: LazyCam Pro question (Read 74869 times)
Saumur
79
on:
February 06, 2008, 04:19:37 PM »
Hi guys.
With LazyCam i can import a drawing but then i don't know where i can set my tool's settings.
Can some1 explain me this?
Logged
Rybot
14
Re: LazyCam Pro question
Reply #1 on:
February 06, 2008, 07:05:03 PM »
After you import a DXF file click the Layers tab at the bottom of the Info window, press the tool button and input the name, diameter, feed rate and so on.
Logged
Saumur
79
Reply #2 on:
February 08, 2008, 09:02:41 AM »
Thanks.
Is there a way to put the measouring unit in mm? Because i work with mm but i can't find where i can change it.
Logged
Chip
2,055
Gainesville Florida USA
Reply #3 on:
February 08, 2008, 07:50:11 PM »
Hi, Saumur
LazyCam works in Units, If your DXF is in MM, Then it's MM in LCam.
Thanks, Chip
Logged
Saumur
79
Reply #4 on:
February 19, 2008, 09:07:06 AM »
can you work in diameter mode with lazycam?
thanks
Logged
Saumur
79
Reply #5 on:
February 21, 2008, 10:27:07 AM »
anyone?
Logged
Chip
2,055
Reply #6 on:
February 21, 2008, 01:47:03 PM »
Hi, Saumur
Lathe uses a Profile top half of your dxf drawing.
Hope this Helps, Chip
Logged
Saumur
79
Reply #7 on:
February 29, 2008, 10:20:44 AM »
Guys, i'm sending you the dxf i'm using.
If you can tell me how i have to configure lazycam to generate a g-code of this i would really appreciate it since i can't do it...
Logged
Saumur
79
Reply #8 on:
February 29, 2008, 11:03:17 AM »
I could do the g-code but i don't understand why when i put the tool it's like the program is not reading it.
In fact if i change the diameter of it the program will be the same.
Do i have to do something in Mach3 too?
Logged
Chip
2,055
Reply #9 on:
February 29, 2008, 05:59:14 PM »
Hi, Saumur
Is it a Lathe profile your looking for ?
Your dxf diden't clean up weii, Loaded it in BobCad, traced it and saved under dif name.
Is this what its should look like.
Thanks, Chip
Logged
Print
Pages:
1
2
3
4
5
Go Up
« previous
next »
