Hello Guest it is September 06, 2026, 11:56:14 AM
Author Topic: Got My mill running :)  (Read 95157 times)
Offline jeep534
  •  123 123
  • From the hills of WV
Re: Got My mill running :)
« Reply #40 on: January 23, 2007, 05:27:32 AM »
oops
My  web site is http://jeep534.smugmug.com
Facebook archies machine
« Reply #41 on: January 23, 2007, 06:25:13 AM »
There are no pics :( IT is an eagel CNC mill that I got for a good price as a test bead. I wanted to have a mill that I could just run and run fast so I went with the servo drives, motors and cables from Automation direct. It is not a cheap way to go but the speed and simplistic set up are great! If you would like to do somthing like that you are looking at about 1500.00 an axis :(
Looked at your page and like the JD you got! I would get one like that if I could find one with the 3PT hitch...
www.newfangledsolutions.com
www.machsupport.com
Offline jeep534
  •  123 123
« Reply #42 on: January 23, 2007, 07:21:55 AM »
What is it about the crawler!!!!!!! i have a bunch of "stuff" but all the "machine heads" seem " Ping"on the John deere  go here www.jdcrawler.com.
archie =) =) =)
Offline jeep534
  •  123 123
« Reply #43 on: January 23, 2007, 07:27:09 AM »
Ok Brian. what Is he total config if the mill. PC, Grex, touch screen and automotion direct servo's and drives. and maybe Quantum and of course Mach3 being fed with featurecam. am I close
archie =) =) =)
Getting close to purchasing parts
« Reply #44 on: January 23, 2007, 07:35:51 AM »
Yup, you know me all to well :) That is about eveything!
www.machsupport.com
Offline jeep534
  •  123 123
« Reply #45 on: January 23, 2007, 07:54:46 AM »
If I could just wave my magic wand and get it to all come together. The lagun will have to have all the electricals replaced as well as all of the ballscrews. X and Y for sure. "we rolled it over and bent the X screw and the Y was having some sort of trouble before it came to me. Rockford ball screws say they can sell me a pair for about 900.00. not sure I want to put 2000.00 in that mill right now.  the Bridgeport is much closer to running. I hope to get the bridgeport running without much else but a Grex. but from some of the post's there seems to be a conversion card required to interface the Grex (stepp direction) to some sort of analog output. If that is so would I be better off just putting in the Biggest rutex drives being fed by the Grex. and using the Bridgeport servomotors and encoders.
archie =) =) =)
« Reply #46 on: January 23, 2007, 08:03:23 AM »
See if you can find a Galil on line... That is how I would do it at this point...
www.machsupport.com
Offline jeep534
  •  123 123
« Reply #47 on: January 23, 2007, 08:12:35 AM »
which model
there are a bunch
Thanks Brian
archie =) =) =)
« Reply #48 on: January 25, 2007, 03:05:33 PM »
18XX or a 23XX just be sure that you get one that is 4+ axis
Brian
www.machsupport.com
Offline jeep534
  •  123 123
« Reply #49 on: January 25, 2007, 09:38:12 PM »
Thanks Brian,
Boy good thing I was setting down. I guess if you want to play with the big boys you have to pay.  2000 for drives, 3000 for control card 1000 for operator Interface(Elo Touch screen plus mount and MPG switches ect. )  500 for pc to run everything plus vfd and I am thinking some sort of IO expansion. I guess 7,000 In round figures. not much if you say It real fast :-)
archie =) =) =)
