Hello Guest it is November 13, 2026, 04:47:46 PM
Author Topic: Got My mill running :)  (Read 97651 times)
Re: Got My mill running :)
« Reply #10 on: April 20, 2006, 01:06:30 PM »
I made my own cables... the breakout is to big and nasty to put in my mill :)
www.newfangledsolutions.com
www.machsupport.com
Offline fdos
  •  326 326
« Reply #11 on: April 20, 2006, 01:08:39 PM »
You should post some pics of the installation Brian ;-)    I wonder if Automationdirect will supply outside of the us.
« Reply #12 on: April 20, 2006, 01:13:25 PM »
I am still setting the mill up :( I have the PLC in the machine and about 50% wired up... As soon as I get it up and running I will post a few pic's of it
www.machsupport.com
« Reply #13 on: April 23, 2006, 09:39:01 PM »
I am thinking of using a Grex and the automation direct drives on a hardinge lathe I am converting. Are the servos on your mill direct drive or do you use a gear reduction?
« Reply #14 on: April 24, 2006, 05:54:47 AM »
they are direct drive on the X and Y axis but Ihave a belt on the Z axis... I now have the mill running at 450 IPM and it seems to be working well... I think it is time to finish wire it and get making chips.... the pen is fun but chips are so much cooler ;)
www.machsupport.com
Offline fdos
  •  326 326
« Reply #15 on: April 24, 2006, 11:48:36 AM »
Not if they are blue ;-)
« Reply #16 on: April 24, 2006, 12:53:43 PM »
I run only blue chips ....
www.machsupport.com
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #17 on: April 24, 2006, 01:27:04 PM »
Blue chips from cutting Aluminium, that would be a novel sight  ;)
« Reply #18 on: April 24, 2006, 01:32:37 PM »
I have tested that and I can't seem to get it... I did run a lefthanded bit into some AL at 12000 Rpm... Art was there forthat one and still no blue. I will keep working on this problem ;)
www.machsupport.com
  •  2,785 2,785
« Reply #19 on: April 24, 2006, 01:37:08 PM »
I have tried for years, lots of clogged up cutters but still no blue chips. Oh well never mind.  ;D
